Stock Tpi?
Old Feb 8, 2004 | 08:30 PM
F-Body Tim's Avatar
Car: 1986 IROC-Z
Engine: 305 T.P.I.
Stock Tpi?
what were the numbers the tpi motors put down? preferably the 86 305 tpi... whant some base numbers .
Old Feb 8, 2004 | 09:05 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
look around the site, not just the forums. Tons of info and here is the part of the site you are looking for
https://www.thirdgen.org/newdesign/tech/techdb.shtml
Old Feb 8, 2004 | 10:38 PM
91305Z28's Avatar
Car: Camaro
does anyone no way in the 91 305 Z28 one has 205 hp and the other one 230 hp?
Old Feb 8, 2004 | 11:15 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: Stock Tpi?
Rated at 190 hp and that's about what they put down too.
Old Feb 9, 2004 | 05:37 AM
SweetS10v8's Avatar
Engine: L98 & 355ci
is he asking what the difference is?
Old Feb 9, 2004 | 12:16 PM
MdFormula350's Avatar
most likely the dual cat option and a cam difference, but not sure.
Old Feb 9, 2004 | 01:03 PM
buymytransam's Avatar
Car: 2005 Audi A4 Avant
Engine: 1.8T
i believe one rating was for the 700r4 and the other was for the t-5. and i think that the two ratings were at different rpm's as well.
Old Feb 9, 2004 | 02:24 PM
Jon92TA's Avatar
Car: 92 Trans Am - Sold
205 hp had 305 TPI, Auto, single cat
230 hp had 305 TPI, 5 Speed, Dual cat
Old Feb 9, 2004 | 06:40 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: Stock Tpi?
Okay guys he did say 1986, so you're a bit high on those numbers.
Old Feb 9, 2004 | 08:54 PM
F-Body Tim's Avatar
Car: 1986 IROC-Z
Engine: 305 T.P.I.
i herd the 86 has a sh!ty cam. why is the 86 have to be gay? is it because i bought one, this sucks.....
good thing i'm puting a 383 w/ a blower in this summer. :rockon:
but the question still remaines, what did 86 (auto) 305s put to the tires, not what GM rated it at 190???
Old Feb 9, 2004 | 09:40 PM
SweetS10v8's Avatar
Engine: L98 & 355ci
I dont know if they stated gross or net HP then so its either 190 or below....
Typically/ For what your looking for you can assume....
Automatics typically lose 20% HP through the driveline.
(152HP)
Manuals typically lose 15% HP through the driveline.(161HP)
Old Feb 9, 2004 | 09:41 PM
SweetS10v8's Avatar
Engine: L98 & 355ci
double post
Old Feb 9, 2004 | 10:50 PM
My86TransAm's Avatar
Well, my stock 1986 put out 158 HP and 235 lb-ft. With my few mods, ###### Cat Back, Ported Plenum, Polished TB, TB Bypass, Ported AirBox, K&N. I now put out 172 HP and 243 lb-ft.
gta90
Sep 15, 2015 04:00 PM
jbd1969
Aug 17, 2015 07:06 PM
Sanjay
Aug 12, 2015 03:41 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
marcusaw
Aug 10, 2015 08:13 AM
