Has anyone done this? did it work?
Old Feb 12, 2004 | 08:58 PM
87iroctpi's Avatar
Car: 92 cavalier z24 for now
Engine: 3.1
Transmission: auto
http://216.121.161.76/files/PlenumPorting.pdf
sounds like a lot of work. Has anyone done this and could you tell a different after doing it???
Old Feb 12, 2004 | 09:11 PM
llvll4l2c91350's Avatar
hmm,,,plenum porting. interesting idea.
do it, it works.
i didnt do mine. when i bought the car someone else had already done me the favor.
Old Feb 12, 2004 | 10:09 PM
5SIZ's Avatar
Car: 1987 IROC-Z
i have ported and siamesed my plenum to match my slp runners, it significantly helps airflow by removing restriction but just doing that wont give you a huge gain, every little bit helps.
Old Feb 12, 2004 | 10:29 PM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
Transmission: Tremec T-56
I would do it, its worth the $3 for the carbide cutter and 30 min. of your time. At least thats all the longer it took me to do a good job on my plenum. Really tho it isn't much work just to do the plenum.
Old Feb 13, 2004 | 07:07 AM
vwdave's Avatar
Dont use carbide. Use Non-Ferrous(sp)
Old Feb 13, 2004 | 09:04 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
It works, and it helps. Look at it before you do it (take a picture) and then look at it after you do it (compare) you will have gained/opened up soo much. You should be able to feel it in the upper RPMs, more so with a modded engine.
Old Feb 13, 2004 | 04:02 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Whatever material cutter you decide to get (carbide, non ferrous etc) use a light oil of some kind as you work on the plenum surface. Motor, gear, two stroke WHATEVER - just make sure it is light. It will speed up the cutting process and save you a lot of time.
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
