ZZ4 cam ?
Old Feb 13, 2004 | 02:33 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
ZZ4 cam ?
A friend suggested that I get a ZZ4 cam for my L98 TPI (MAF), i've already got the "mild" SLP cam for that block in it, but I don't know the specs on it. Any recommendations for or against the ZZ4 cam setup ? Also, where do I get it ?
Old Feb 13, 2004 | 06:24 PM
ThirdGenFire's Avatar
Car: 2000 Trans Am and a 85 Iroc-Z
Engine: The Mighty LS1& 305 just beat meTPI
Transmission: 4L60E and 700R4
Here you go Randy.
Adv. duration 287/287, duration @.050 226/226, Lift .520/.520. 112 LSA. This is the ZZ4 Cam.
The SLP's are slightly smaller.
Camshaft Specs: Valve Lift Duration Duration@.050
in: .495" 270º 218º
ex: .502" 276º 224º
Part number from SLP is 51004
Hope that helps. See you tonight at the meeting.
Old Feb 13, 2004 | 06:30 PM
oh heres the radiator info as well. from summit
Griffen has one for 189.95 adn they have their brand for 169.95
Old Feb 13, 2004 | 06:37 PM
Shaun 90 Iroc's Avatar
Car: 1990 Iroc-Z
Engine: 350 L31 Vortec
? The zz-4 cam is 208/221 @.050 .474/.510 112lca
Old Feb 13, 2004 | 07:10 PM
Car: 1987 IROC Z
Ok... best price on the ZZ4 ?
Old Feb 13, 2004 | 07:14 PM
Car: 1990 Iroc-Z
check SDPC2000.com
=) and depending on which heads you are using you might need springs.. i used the LT4 springs.
http://www.sdpc2000.com/cart.asp?act...d=989&pid=1438
Old Feb 13, 2004 | 07:19 PM
Shaun 90 Iroc this is from THeir catalog not my own mind. Thats what they put in their own words.
$375.00 even. Hey I saw in my LPE catalog that they have a good cam for you as well.
They are a bit cheaper with about the same amounts of lift. These are numbers with the 1.6 rockers.
Looks to be about $60 less than the ZZ-4. 74211 looks to be the better one for you.LPE
Old Feb 13, 2004 | 09:54 PM
Mark 89Formula's Avatar
Originally posted by ThirdGenFire
Shaun 90 Iroc this is from THeir catalog not my own mind. Thats what they put in their own words. [/URL]
The catalog you're quoting is TPIS and the cam is the ZZ-409. That's not the same as the ZZ-4 which is a GM engine/cam. Shaun's listed the correct ZZ4 specs.
Old Feb 13, 2004 | 10:22 PM
Don 91RS's Avatar
I bought a take-off ZZ4 cam from Sallee Chevrolet. $105 including shipping. http://www.sallee-chevrolet.com/sales.html
Old Feb 13, 2004 | 11:30 PM
Raiden's Avatar
You can pick up a zz4 cam on ebay pretty easy for $135.00. I have been looking at them. I'm considering the lt4 hot cam, but I don't want my gas mpg to go way down..
Old Feb 14, 2004 | 01:29 AM
Yeah I know. I just noticed my post. Sorry.
Don't worry I know the differences between them all.
Old Feb 17, 2004 | 08:33 AM
Captain C's Avatar
Car: 1985 IROC-Z
Engine: 1989 350 4 bolt roller block
Transmission: ProBuilt 700R4 Road Race with Edge 9.5" 2800 stall lockup converter
Sounds like you've got a slightly hotter cam in the car than the ZZ4 already. Why go through all that work for so little difference? If you are looking for more power, use 1.6 rocker arms or go to better heads.
You can gain 30-40 hp just by changing the heads with no cam change....... The L-98 heads are not really very good compared to modern heads. The 385hp HO motor is a ZZ4 with the quickburn heads and 1/2 point lower compression. Everyone I have heard from that has run one on a dyno has put out 390hp or better....
Old Feb 17, 2004 | 01:00 PM
Car: 1987 IROC Z
What about this LPE cam as compared to the ZZ4 and SLP.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEBWA%3AIT
Old Feb 17, 2004 | 02:15 PM
Raiden's Avatar
The duration of hte zz4 is 208/221 on 112 lca.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Magman
Sep 13, 2015 12:14 AM
Strick1
Sep 4, 2015 07:11 AM
