Edelbrock Or Trickflow Heads For Superram&zz9
Old Feb 19, 2004 | 12:48 AM
MRIROC's Avatar
Car: 87 IROC
Engine: 355TPI SUPERRAM
which heads are better suited for the superram.this is not a daily driver.ill drive it in the summer only on the weekends and at the track.i have to pass emissions.i cant afford AFR's.
Old Feb 19, 2004 | 12:51 PM
MRIROC's Avatar
Car: 87 IROC
anybody?
Old Feb 19, 2004 | 04:55 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Of those two heads I would say the Trick Flows. They flow a good bit more than the Edelbrock's from what I have seen. You will need to change springs on the TFS heads though to run a decent sized cam.
Old Feb 19, 2004 | 06:05 PM
MRIROC's Avatar
Car: 87 IROC
im gonna get the spring upgrade if i get the trickflows
Old Feb 19, 2004 | 09:10 PM
OMINOUS_87's Avatar
Your gonna need a spring upgrade on either head, if you run a decent roller cam, 211, 219, or XE roller stuff.
Old Feb 20, 2004 | 01:46 PM
MRIROC's Avatar
Car: 87 IROC
so will the 195cc runners be too much fot the superram?ill be running a 2800 stall so if i loose any torque the stall and the gears will make up for it.i hace 3.73's with auburn posi.i just want it to pull pretty good top end and i just dont know if the 170cc runners on the edelbrocks will flow up high.
Old Feb 20, 2004 | 04:13 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Out of the box quality: Trickflows
Plan on further port work anyway: Edelbrocks
So it depends on what you plan to do with the heads IMHO.
Old Feb 21, 2004 | 11:18 AM
MRIROC's Avatar
Car: 87 IROC
so the trickflow is a good quality heads?and the 195cc heads wont be overkill for the superram?
Old Feb 21, 2004 | 11:56 AM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Edelbrock 60739 heads have 170 cc intake ports, 2.02/1.60 SS valves and can be gotten with springs capable of .575 lift at no additional cost too.
They are under $1,000 complete, ready to bolt on, have CNC intake and exhaust ports (in about 1/1.5 inches) and flow 244 CFM @ .500 and .500 (based on their website and emails I have received from their tech support). They also have outstanding exhaust ports with great intake to exhaust flow ratios.
Always consider port size Vs cfm flow when looking at heads; not just max flow numbers. Small ports which are STILL capable of good flow at higher valve lift indicates excellent velocity.
Low and mid valve lift flow is more important than max flow.
Just my thoughts.
Jake
Old Feb 21, 2004 | 01:16 PM
MRIROC's Avatar
Car: 87 IROC
thanks jake,good point.do you know if theres enough extra meat on the edelbrocks for porting?
Old Feb 22, 2004 | 05:20 PM
JakeJr's Avatar
Axle/Gears: 3.07
No, there's not a LOT of meat left in the casting.
When I had mine off a while back, I use my index finger and thumb to get an idea of how much metal there is for porting, and there isn't a lot.
I suppose Extrude Hone could take it out to the max if you decided to go that route. You can give them a call; I'm sure they have more exact data that my "index/thumb" provides.
Jake
Old Feb 25, 2004 | 02:08 PM
MRIROC's Avatar
Car: 87 IROC
so which ones will net me the best et's?
Old Feb 25, 2004 | 02:23 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Get the aluminum Edelbrock Victor Jr. 23* SBC heads. You can get them with springs that will support your cam too. I've personally read too many negative things about the trick-flows for me to do business with them.
The Edlebrock Victor Jr's are nice heads.
Old Feb 26, 2004 | 01:29 PM
MRIROC's Avatar
Car: 87 IROC
VICTOR JR. WOULD BE TOOOOO BIG OF A INTAKE RUNNER.ANYTHING OVER 200CC IS TOO BIG FOR THE SUPERRAM
Old Feb 26, 2004 | 01:50 PM
JakeJr's Avatar
Axle/Gears: 3.07
Exactly!
Those are the ones I plan to go with when I decide to change heads. With the CID I have, they should be perfect.
Jake
Old Feb 26, 2004 | 02:36 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
You can easily port a super-ram base to accomidate victor jr. heads.
Port matching is a good thing.
Old Feb 26, 2004 | 05:25 PM
OMINOUS_87's Avatar
No you can not port it easily.
Vic Jrs require a Felpro 1206 intake gasket, to match any TPI lower you will have to weld in some alluminum and then have the base milled out.
Not a job for a shade tree mechanic by any stretch.
Not to mention Vic Jrs are rev heads, they like to hang in the upper Rs with big lift solid cams.
Old Feb 26, 2004 | 06:36 PM
cali92RS's Avatar
Car: White KSwisses
Engine: 5.3L Gen III
He said he needs to pass emissions. The victor Jr's dont have egr provisions, while the TrickFLow 23* do.
Old Mar 1, 2004 | 02:29 PM
formula350sd's Avatar
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
id go for trick flow a friend of mine is running them on a 383 super ram motor with lt4 hot cam and his car doesent have trouble with emissions and walks away from most its competition and get almost 20 miles a gallon on the highway thats where its at if you ask me
z28guy134
Sep 1, 2015 11:50 PM
italiano67
Aug 31, 2015 06:04 PM
earlpote
Aug 28, 2015 10:42 AM
86IROC112
Aug 17, 2015 02:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
