code 33 ?????
Old Feb 24, 2004 | 10:12 PM
bottlefedIroc's Avatar
code 33 ?????
my car is setting a code 33 i have replaced the maf map sensor and the tps so what else can it be? The car seems to studder when i first hit the gas. Could my ecm be going out. any help would be much appreciated!
Old Feb 24, 2004 | 11:04 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hey bottlefedIroc,
I have sent you some e-mail that may help.
Old Feb 25, 2004 | 03:37 PM
thanks i will look at it
Old Feb 25, 2004 | 04:10 PM
Trickster i never got anything
Old Feb 25, 2004 | 08:30 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
e-mail????
I sent it to the e-mail address listed in your profile. If that is not correct, send me a good address.
Old Feb 25, 2004 | 08:41 PM
thats the wright address but for some reason its not coming up so send it to jr7ky@aol.com
Old Feb 25, 2004 | 08:56 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It's in the mail listed as code 33 info.
Old Jun 10, 2004 | 07:48 PM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
trickster, im getting code 33 on my iroc too... can you send me that email? djhafownz@cofs.net =) thanks
Old Jun 14, 2004 | 08:11 AM
mike88form350's Avatar
Car: 88' Formula 350
Engine: 358 ci TPI
Transmission: Tremec T-56
if you threw parts at the problem and that did not solve it, it's most likely a wiring problem. check the voltage at the dark green out put wire of the maf. turn on the igniton and check the voltage. if you get a near zero reading check the voltage of that green wire at it's connection to the ecm, terminal b-12. if 5 volts there is an open in the green wire somewhere that needs to be fixed. if zero volts and the connection is OK...replace the ecm : .
back to when you turn the ignition on... if you get 5 volts check the purple power supply wire to the maf. if 12 volts check the maf ground. if you get 12 volts find terminal G on the ALDL connector in the car, apply 12 volts to G. recheck the purple wire for 12 volts. if you still don't get 12 volts check the wiring to the maf power relay. if the wiring for the relay is ok replace the relay. before you go and buy a relay take it out and test it by applying 12 volts and a ground to the low current coil side of the relay. it should click not rattle or vibrate. i hope this helps somewhat.
if you find a flow chart for this code at the end it tells you to check the fuel pump fuse, if ok, replace the oil pressure sending unit. this is because the oil press. send unit acts as a back up for supplying voltage to the fuel pump. good luck.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
