Pictures of Holley Stealth Ram Install.
Car: 89 Formula L98 power
Engine: '96 subaru, opposed 4banger
Transmission: TH700R4, subaru 4WD
Axle/Gears: 3.27, just works
Hi guys, I'll be installing a Holley Stealth Ram within the next month and a half on my 89 formula 350 along with alot of other go fast goodies.
I would like to see anyone with the stealth ram on there cars. Please post your pics here, I'm curious to see how everyone else did their install. Thanks.
My homepage:
http://members.cardomain.com/id/cronsformula
My homepage:
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: Pictures of Holley Stealth Ram Install.
My homepage:
http://members.cardomain.com/cronsformula
My homepage:
Originally posted by 86WS6_T/A
What kind of elbow is that coming off the front of the intake?
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
Originally posted by CaptPicardsZ28
I bought it from Summit. Look in the fuel injection/tpi section. I believe its an LT1 elbow.
yeah I've seen all the ones on stealthram.com already, but I'm sure that theres others out on this board that don't have there car on that site. Thanks #1, lol.
Originally posted by tpiroc
Glad to see that fits! I plan on using that particular elbow for my someday custom LT1 intake
85TransAm406 What size is the round part of the elbow? 3"?
Yes I believe so...you can call summit and ask. I cant remember. My intake is flared to 3 1/2".
cronsformula350 yeah I've seen all the ones on stealthram.com already, but I'm sure that theres others out on this board that don't have there car on that site. Thanks #1, lol.
Commander Ryker is #1...I am the Capt. I may have to send a Borg after you if you get it wrong again. They are not very nice to deal with...
haha, I like the old school star trek more than the next generation one, lol, its just so much funnier.
Car: 87 Irocz, 95 Z28, 71 Z28 /RS
Engine: 355 Tpi, LT1, 355
Transmission: Auto, Auto, 4sp
Once everything is installed in my car I will post pics.
As for that Elbow I dont know about that. I stuck to the Org. Airbox system in my car.
Car: Transam
Engine: ZZ4,Holley Stealth Ram,Commander 950
Why are there no Transam pictures here.Has anybody fitted the HSR to a TA and managed to shut the hood without any mods?
Mine is on its way and thats the only problem i can envisage.
cheers
PM
cheers
PM
Car: 1985 Trans Am
it'd have to be an aftermarket hood, or mods are mandatory. That's why i went with the LT1 intake. I love the HSR idea, but could bring myself to cut on my hood. It'll be fine with the hood mods though. Only other option i can think of is lowering the motormounts with some other type of mount, or machining on the intake itself.
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
because there are pics of TAs on www.stealthram.com particularly mine and jerod matlock.
Car: Transam
Ive been a regular visitor to the stealthram site and have been in touch with Jerod.
I realise i'll need to cut the hood bracing out but will this be enough.I will be using standard engine mounts and not poly ones.
PM
PM
Thank *** I have a Camaro since it just fits in just nice under my hood.
Car goes to the shop for headers & cat back system in the car as soon as he gets back later this week.
good to hear, of more guys out there with the hsr on pontiacs. When I put myne on my formula, I'm putting my factory 6 cylinder hood from a '84 firebird on my car, with some cutting of the inner bracking. It will clear the HSR, and I won't have a problem, I'm putting a 5" scoop on it from glastek and pick up some subtle looks, that are tasteful. Its funny that I'm going with that hood, it just looks so good for the car, alot of the other ones, I don't think fit the body lines as well, especially for the money.
Homepage: http://www.cardomain.com/id/cronsformula
Engine: 360 HSR
PM
PM
nice, nice, keep the coming fellas, lets make this the biggest post with pics of hsrs on our cars!!!
Engine: 360 HSR
how about sending them to me over at www.stealthram.com that way i can put all of us together in the HSR CARS section.
Yeah that would be cool too, but I still have to install myne, so no picture yet, car will be done by the end of april.
cronsformula350:
I noticed that your from IL. How can you run HSR, and still pass emissions? I'm planning a 350 swap, but skipped the HSR idea b/c I've read it won't pass and isn't emissions legal. Where I'm at, it only goes through the sniffer, but I'm not about to do all that work and spend all that money, and it's not going to pass!
Also, how much power to the rear is the tpi going to throw down now w/ the HSR?
Car: 1985 Trans Am
I've seen cars with no cats pass emissions. They weren't running optimized timing/fuel curves, or a big cam or anything, but it can be done. You can just change chips after your testing.
well, since they don't look under your hood in joliet, or the downers grove emissions stations, they test your gas cap, and put your car on the dyno and check emissions at driving between 25-55, and if you pass that, your good. Theres no visual.
However, I have a waiver so I don't have to take emissions, at all since the car is driven less than 3K miles a year, and is insured as a show car, driven for recreation only, not for taking to work or school.
Of course you can drive it to work or school, its unlikely that a cop would pull you over and ask you, since the plates are the same as any other.
The egr, doesn't help you pass, it simply works at partial throttle, and works off the idea of using combustion gases, to cool the chambers, silly idea, works, but isn't needed.
Just to prove the point that the egr isn't needed, I passed emissions with the timing advanced, tps turned up, and the egr disconnected, no vacuum solenoid at all, still passed better than my moms 92 lumina, with a new dynomax cat, and myne passed with 25000 on the cat, and passed with lower emissions, OUT OF A V8!!! It was amazing.
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
Originally posted by SweetRide45
cronsformula350:
cronsformula350:
a good cat, fuel pressure regulator, plugs, wires, cap, rotor, coil, o2 sensor, cts.
Car: 1985 Trans Am
No, any car cannot pass emissons without equipment. It's just that a well-tuned car can. Of course a 130,000 mile motor with 20% leakdown in three cylinders isn't going to pass emissions without help.
Car: 1987 firebird formula
Hey guys!!!
I am on a tight budget all of the time and that gets frustrating when you have to constantly teardown and put back together.
Anyways I have decided to go with the HSR and i like it all ready even on top of the STOCK ewwww L98 heads and cam and manifolds. The shift point has moved up to 5200 - 5400 RPM
And i can feel the potetial that this Manifold will have. I unforutnatly have to drive it daily right now which cuts into working on the car over a period of time. The unexpected self destruction that my other car undergone ment that i couldnt take my time and do everything that i wanted to right now. Either way here are my work in progress pictures, mods, and soon to be mods. Please tell me what you think.
1987 Formula 350 TPI
Current Mods:
HSR Manifold
Modified 89 ARAP Prom
30lb accell Injectors
52mm Holley Throttle Body
1.6 Comp cam Stamped Roller tip Rockers (FREE)
Coolent Bypass Mod
A/C Delete
Smog delete
Converter delete
Custom (work in progress) air intake
Rebuilt 700r4 trans cant remeber what stall
B&M megashifter
B&M stage two shift kit
Flowmast Muffler
Hopefully in the near future mods:
AFR 195 heads
Still thinking about Cam
Headers
Subframe connectors
And lots of custom prom burning
Wonderbar and lower control arms to be installed next weekend
I do have a question for everyone, If i should stick with cutom prom burning (amature) Or go with a holley commander type setup.
Please let me know what you think and remeber it is work in progress.
Current Mods:
HSR Manifold
Coolent Bypass Mod
A/C Delete
Smog delete
Converter delete
B&M megashifter
Flowmast Muffler
AFR 195 heads
Headers
Subframe connectors
Hey cron,
Where do you live? I swear that one of the girls on your CarDomain page lives right down the street from me. The second Shannon.
I'm in Homer Glen.
Anyway, when my HSR gets here I'll have you help me install it if you do live close.
Thanks for all the pics and info from anyone else.
I'm in Homer Glen.
I'm on the outskirts of homer glen, almost into new lenox, if you ever want to hang out dude, look me up on aim, Formula3Fity, I'd be up for a cruise, or if you want to come out to the track with me or the dudes in my club, I'm probly going out to the steak and shake off harlem today. OH yeah shannon sullivan is hot as hell, ttyl bro, nice installs guys, I'm ordering some edelbrock coated shorties, then a cam, and a stealthram intake for my L98 Iroc, I chirped third last night on cedar road, man the porting I did to my base, has made a huge difference, it pulls in third up to 90 almost as good as it does in second, I'm curious to see what it will run a 66 the way it is right now.
Nice, I've got a spare TPI setup in the garage right now that I'm porting out. I'd probably have the bastard done if I could quit breaking bits on my dremel. After that I'm working on an LT1 heads/intake/cam setup that ought to rock. I just hope I can keep the stock short block alive with 161k miles on it. lol
I put Edelbrock shorty headers on my car last week and the butt dyno tells me that the car gained a ton of power throughout the powerband. I'm going to try to make it out to RT66 on Tuesday. I start a new job on Monday so hopefully I won't have to stay that late. I'll probably end up going straight from work.
I'll PM you my cell number in case you end up going. Maybe we can get together and shoot the **** in the staging lanes. Oh, if you need any tuning done after the HSR install, I've got an AutoProm setup too. All you would need would be a Moates adapter and a chip.
Anyway, I'll TTYL.
-TJ
Anyway, I'll TTYL.
-TJ
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
9192camaro
16
Feb 3, 2019 12:21 AM
L98GTA87
Aug 11, 2015 06:55 PM
