Cleaning a Dirty MAF Sensor; How?
Old Mar 7, 2004 | 01:04 AM
tpiroc's Avatar
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
I started dismantling my sad 305 last night and noticed the rubber ring between the MAF and snorkel was missing, and that unclean air had been entering though a very small gap. The front surface of the screen was all discolored and dirty. I was wondering if there's a safe way to clean this guy without damaging it. SD may be in the future anyway, but I just wanted to know
Old Mar 7, 2004 | 08:31 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Brake cleaner worked for me and others with no bad results.
Old Mar 7, 2004 | 08:42 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Heard of folks using brake cleaner, its not my forst choice some of them can and will melt plastic so tread lightly...
If your going to use anything i siggest using electronics parts cleaner,,,, should be able to get it at larger auto stores and radio shack etc.... made for this kind of stuff
later
Jeremy
Old Mar 7, 2004 | 11:40 AM
FrozenFirebird's Avatar
At the shop I work in, we clean a lot of MAF sensors and we just use carb cleaner, in moderation of course. Havent had any problems with the carb cleaner destroying any electrical parts, or plastic.
Old Mar 7, 2004 | 10:21 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Personally wouldn't use Break Clean or Carb cleaner myself. AutoZone or any other parts store has electrical clean in a can like brake clean for a few bucks.
Old Mar 8, 2004 | 06:21 PM
89Formula5.7's Avatar
Car: 89 Formula 350
Engine: L98 w/ Stealthram
Axle/Gears: 9 bolt 3.27
I personally think that brake cleaner and carb cleaner are too aggressive for a MAF. I used electronic parts cleaner. I got it at Auto Zone.
Old Mar 8, 2004 | 08:46 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Why not just remove the screens? There's probably a thin film of dirt or oil on the center element, too. So then you'll be able to use a small, dry artist's paint brush to dust that off. That's what I did, and it worked very well. Just be gentle.
Old Mar 9, 2004 | 11:55 AM
Roostmeyer's Avatar
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
Isn't that what the MAF burn off relay is for? To heat it up enough to burn off anything on the element?
Logan Bryant
Aug 27, 2015 11:52 AM
Bert87
Aug 23, 2015 03:50 PM
mdtoren
Aug 23, 2015 12:52 PM
perZ
Aug 21, 2015 05:51 PM
mdtoren
Aug 16, 2015 05:45 PM
