Any tips on improving mileage?
Car: 1991 Trans Am GTA
Engine: 350 TPI (L98)
Transmission: TH-700r4
I get around 15 miles per gallon, according to the converter anyway, to me it's 15 litres per 100km, I would like to get it to something like 11-12 litres per 100km.
Any tips on what one can do to improve fuel economy?
With my summer tires and better road conditions I think I get around 12 litres per 100km though.
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
I would add a better flowing air filter, such as a K&N.
Other than that, I would make sure the car has a good tuneup (plugs, plug wires, cap, rotor).
Hope this helps.
Hope this helps.
Car: 1986 IROC, 1983 Camaro Convertible
Engine: Both 305
Transmission: Both 700-R4
My opinion on the matter is if you want fuel economy you buy a four banger. You buy a 350 for performance and power.
Car: 1992 Black Z28 Hardtop
Axle/Gears: 2002 10 bolt w/3:23
My Z gets about 26.5 mpg. Even driving hard it does in the 17mpg range. I expect it to do good heck I have friends with LS1 vettes doing 31mpg. Do a good tune up with the best parts, keep tires inflated properly, use synthetic oils that will help.
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
on my L98 i only get around 13mpg highway or intown is this wrong? i never get more than 170 to the tank no matter how light i go on the gas
Originally posted by gmgod
Make sure the car is in good tune as stated above and add headers/catback.
Car: 91 GTA
Originally posted by 87Formula4bbl
The biggest fuel-saver I've found is keeping my foot off the gas.
Originally posted by HisDivineShadow
Language barrier, could you give me the full names? I'm just guessing those are abbreviations because they sound like it.
As mentioned earlier. a good state of tune and synthetics are always good and make sure your ECM isn't throwing any codes. One thing I am sure they implied is that in the tune up, the oxygen sensor often times gets replaced (it does on mine at least) Also, dirty injectors and a clogged catalytic converter can also cause poor mileage. Good luck!
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
Re: Any tips on improving mileage?
Wow, that seems pretty low. I get about 20 or 21 in town, and 24-25 on the highway (in the camaro). In my truck I get about 17 in town, 19 on the highway.
Re: Re: Any tips on improving mileage?
Originally posted by Pro
15? This is city driving I assume?
This is what I think anyway, I measured this week and it was 16 miles to a gallon, I should see what happens when summer comes and I can use my summer tires and the weather is hot.
It does around 1900/2000rpm at 60MPH and 1500/1600 at 50MPH and if that tells you anything, maybe the rpm's should be a little lower I've thought.
Car: '89 GTA
Engine: a bunch of pieces
Transmission: still there - very stockish TH700
Your Divine Shadow
A year ago I've made a 1800 km trip (Poland-Germany-Poland) in December, the temperature was around -10 C (sorry for C scale, guys), highway mileage of my stock '89 GTA was under 9,5l/100 km, avg speed was 80-85 mph. I'm sure you'll get better mileage when you start cruizing at distances longer than 1 km
Mike
Mike
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
