Superram bolted up to a Scoggin-Dickey Vortec Intake
Old Mar 17, 2004 | 11:16 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
Has anyone tried bolting up the Accel Superram upper intake to Scoggin-Dickey's lower Vortec Intake with Vortec heads. Any clearance problems? The Superram is rather large upper intake.
Feedback? Do you think it will fit?
Old Mar 18, 2004 | 08:41 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
I think this has been discussed before.. If I remember correctly, the drivers rear pair of intake bolts interfere with the superram...
Old Mar 19, 2004 | 10:49 AM
Parrydise7's Avatar
Yes, it has been discussed ad nauseum. Do a search. There are a variety of challenges.
Old Mar 20, 2004 | 08:45 AM
vexter's Avatar
Car: '88 Iroc
Axle/Gears: 3.45
Challenges which can all be overcome... If you really want to run superram+vortecs, you can do it.
Old Mar 21, 2004 | 10:17 AM
burnout88's Avatar
Car: 88 IROC
I ran a couple of searchs cannot seem to find those old posts on this combo. Can someone point me to one or go into a little more detail as to what the "challenges" are?
Old Mar 21, 2004 | 11:33 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
You will have to re-drill the intake bolt holes in the Vortec heads to match the SBC pattern of the Superram base.
Old Mar 21, 2004 | 11:50 AM
c4boom's Avatar
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
no i think he is talking about using a vortec base allready
Old Mar 21, 2004 | 10:36 PM
burnout88's Avatar
Car: 88 IROC
That is correct, I want to use the Vortec base and the Superram upper intake and runners. Has anyone tried this? The Superram upper intake is so large I thought I might have clearance or alignment problems bolting it up.
Old Mar 21, 2004 | 11:02 PM
OMINOUS_87's Avatar
I run it.
It needed some love to get it to work, but works it does.
Old Mar 25, 2004 | 11:25 PM
burnout88's Avatar
Car: 88 IROC
Do you have any pic's? How much Love are we talking about? Grinding?
Old Mar 26, 2004 | 12:52 AM
OMINOUS_87's Avatar
Final pic, well second to final but most work was finished i this pic, most current I have.
What are your motor plans, I will comment, and you at that time should consider doing this combo, it is not a easy walk to get things harmonized.
Attached Thumbnails Superram bolted up to a Scoggin-Dickey Vortec Intake-5.jpg
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
