Weird idle problem
Old Mar 19, 2004 | 10:20 AM
pwdbychevy's Avatar
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
Weird idle problem
After a while of driving around town, my idle shot up to 1500 rpm for no reason. I got no SES light or nothing. I replaced the IAC motor and everything was fine but then again after driving around town in stop and go traffic, the same problem. The idle all of a sudden jumps up to 1500-2000rpm. What the heck is going on? What other sensors dictate exactly what tells this idle motor to open up so much? I temporarily put a piece of duct tape over the IAC intake hole on the TB to keep the idle around 750 in traffic. The engine is a 305 TPI (conversion) SD system.
Old Mar 19, 2004 | 03:11 PM
pwdbychevy's Avatar
ttt
Old Mar 20, 2004 | 08:40 AM
pwdbychevy's Avatar
Can somebody help a brotha out?
Old Mar 20, 2004 | 03:06 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Check the TB and IAC passages fopr being clean and open...
Have u set the IAC per the article on this site?
If not do that next.....
Also u had to do some ecm repinning i take it? Double and triple check what u repinned and verify all connections at ecm as well as the grds on the back of the cyl head
later
Jeremy
Old Mar 21, 2004 | 07:41 AM
pwdbychevy's Avatar
later
Jeremy
I didn't do any repinning. I replaced the entire harness and ecm. The IAC passages were cleaned but it starts to idle high only when driving in stop and go traffic for a little while.
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Cleotiz
Jan 6, 2018 08:56 PM
CORV3TT3
Aug 23, 2015 11:26 AM
