air/feul ratio meter going crazy????
Old Mar 19, 2004 | 04:36 PM
twolfe's Avatar
Car: 91z28
Engine: 5.7 l98
Transmission: AT :(
I just installed a autogage air/feul ratio meter in my 91 z28 5.7. When im driving normaly or idleing it sweeps from lean to rich very fast. it even sweeps so lean that it doesnt show any led's.. when i am at wot it is 2 bars in to rich. and holds constant. i have a new bosh o2 sencor 400 miles ago when i put on headers (hooker 2055's) any sudgestions on why this is happening >??? is this normal?? what should i do??.. any help would be appreciated..
thanks
-Tony
Old Mar 19, 2004 | 05:59 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
That sounds pretty normal for those things. They are pretty useless. It should switch from rich to lean and back again fast because that is what the computer is telling it to do in a way. The computer gives the engine more fuel and then when it reads rich it takes fuel away. It does that constantly.
Old Mar 19, 2004 | 06:50 PM
BOTTLEDZ28's Avatar
Transmission: A4
yep sounds like its working fine to me. I had one in my car and I took it out becuz it was so usless. It had mine mounted outside under my cowl and it looked cool at night but that was it.
Old Mar 19, 2004 | 07:24 PM
twolfe's Avatar
Car: 91z28
Engine: 5.7 l98
Transmission: AT :(
thats odd.. so the a/f mixture fluxuates that much? .. thanks..
Old Mar 19, 2004 | 07:43 PM
BOTTLEDZ28's Avatar
Transmission: A4
actaully, it flucuates even faster then that. The computer is constantly trying to maintain the proper air/fuel ratio and there are so many variables in your driving style that can change the ratio.
Old Mar 19, 2004 | 07:45 PM
Raiden's Avatar
Mine fluctuates quite a bit tto, but it did start moving really really fast and turns out the O2 sensor was bad.
Old Mar 19, 2004 | 08:24 PM
twolfe's Avatar
Car: 91z28
Engine: 5.7 l98
Transmission: AT :(
yea iits annoying, it sweeps the full lean/rich 2 times a second.. then stops,, then leans out and all light s out.. oh well. it works on WOT..
Old Mar 19, 2004 | 10:38 PM
mike89-350's Avatar
Car: 89 formula 350
Engine: 355
You got to be careful with what you get at a part store. I work at one, and we get complaints all the time on bosh o2 sensors. It could be bad. Thats the type of thing that I don't buy from my own store. but those o2 sensors suck anyway.
Old Mar 20, 2004 | 10:16 AM
Battery's Avatar
Car: 75 & 82 Z-28
Transmission: Saginaw 4 speed
The only thing those are good for is determing if your 02 is bad or not. At least those are my thoughts anyways.
Old Mar 20, 2004 | 11:17 AM
twolfe's Avatar
Car: 91z28
Engine: 5.7 l98
Transmission: AT :(
yea they got me for my $ on that one. ill know better next time.... live and learn... thanks for the feed back fellas
InfernalVortex
Apr 20, 2021 11:31 AM
RS Reaper
Oct 17, 2018 07:52 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Zell1luk
Sep 29, 2015 10:36 AM
