High RPM S/C Whine?
Old Mar 20, 2004 | 11:22 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
High RPM S/C Whine?
When i floor my 91' GTA LB9 i hear a really noticeable forced induction whine from inside the car. I have a DIY CAI with a K&N filter and ported plenum (egr walls, siemesed) and Flows. Is that normal or is something wrong. It sound like s/c whine from 3000rpm up.
Old Mar 21, 2004 | 10:20 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Altenator maybe?
With a good cold air intake and open element you will hear a hiss of air coming in... not a whine.
Old Mar 21, 2004 | 05:11 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Would a alternator do that? It only does it at wide open throttle though.
Old Mar 21, 2004 | 07:52 PM
onebinky's Avatar
Where's it sound like the noise is coming from? Engine compartment, mid car, or rear? Could be that you have to much backlash in the gearset from wear, and it's spreading just enough to make noise when you mash the go pedal.
Like D Stroy H8 said, if you have a free flowing intake you'll hear air hissing into the intake because all the factory baffled crap is removed.
Other than that, I dunno. Pop the hood and rev the engine to about 3000 rpm and listen for noise.
Good luck
Old Mar 22, 2004 | 07:27 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Never thought about that, but it does sound just like a Gear Drive timing gear.
Old Mar 22, 2004 | 07:28 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Never thought about that, but it does sound just like a Gear Drive timing gear. Whats the backlash?
Old Mar 22, 2004 | 08:42 PM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
i had the same problem... whenever i revved my engine, it would whine like if i had a s/c inside the engine. never knew what it was though... wasn't sure if it was a vacuum leak or if it was something else
Old Mar 22, 2004 | 09:48 PM
onebinky's Avatar
backlash is the amount of air between two gears, in this case it's the ring and pinion. It has to be set to an exact spec, usually .008" to .015".
Old Mar 22, 2004 | 09:54 PM
TheMysticWizard's Avatar
Car: 1987 Firebird Trans AM
Engine: 383 TPI...very soon
Transmission: TH700R4
I have the same sort of thing going on... Check your belts? I dunno... I'm interested in the answer my self.. mine is definetly from the engine... nice little whine, makes me sound like I have a Blower or Supercharger...
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCtometal
Sep 2, 2015 02:01 PM
