How do I fix this
Old Apr 4, 2004 | 12:55 AM
Z03Z28's Avatar
Car: 92Z28,98LegacyGT,ZX9R,91 Z28,02 Z71
Engine: 350,307,2.5,900cc,5.0
Transmission: 700r4,4spd auto,700r4,4L80
Axle/Gears: 323,?,323,?,373
How do I fix this
I have a 92 Z28 350tpi it runs rich.I didn't get any
trouble codes.What would cause this?
Old Apr 4, 2004 | 08:21 AM
kevinc's Avatar
Car: 1982 Z28
How do you know it's running rich?
Old Apr 4, 2004 | 11:05 PM
Z03Z28's Avatar
You can smell it,and it failed the tail pipe test.
Old Apr 5, 2004 | 12:30 AM
DON 88T/A's Avatar
Any mods?
I live in MD as well...
I run a straight pipe,fuel reg,advanced timing untill emissions then I switch to a cat/ base fuel/timing and actually get the
"fast pass" when I do emissions...
Old Apr 5, 2004 | 07:21 AM
Z03Z28's Avatar
It's all stock right now,just a trans rebuild.
Old Apr 5, 2004 | 07:40 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
does it have alot of miles on it?
have you checked you charcoal canister connections?the filter could also be clogged in the canister?
Old Apr 5, 2004 | 07:44 AM
Z03Z28's Avatar
Just 61,562 miles on it.
Old Apr 5, 2004 | 09:58 AM
kevinc's Avatar
Car: 1982 Z28
Did you get it to flash code 12? If not, do that first...verify the ECM is happy.
If you get 12, the ECM is getting a bad input from one or more sensor(s) and it doesn't know the data is bad.
You have a couple of options, you can try to track down a scantool and see what the ECM is doing. Look for it to go into Closed Loop mode. Look at the sensor inputs, particularly the Coolant Temp. You'll probably find it's staying in Open Loop mode, and you'll see why.
Or you can throw sensors at it, starting with Coolant Temp Sensor and moving on to Oxygen Sensor, etc....you'll hit it eventually.
-Kevin
Bubbajones_ya
Oct 25, 2015 08:01 PM
Reid Fleming
Oct 10, 2015 09:56 PM
dusterbd
Sep 29, 2015 08:40 AM
z28joe2
Sep 28, 2015 05:54 PM
mfp189
Sep 27, 2015 09:25 AM
