88 iroc rebuild
Car: 82 El Camino
Engine: built 355
Transmission: T-56 upgraded internal
Axle/Gears: 10 bolt 3.42
88 iroc rebuild
ok im thinking about buying an 88 iroc, its got about 124k on it, and the present owner says it still runs strong, but for my own piece of my mind i wanna rebuild the engine. Ive been looking through summit and there are tons of kits available, which one do i need. Im thinking having it bored .030 over and then just replacing all internals. This wont be anything crazy for now, and im kinda limited on money, can someone offer me what to do and where to start, any and all suggestions will be greatly appreciated. Also im gonna be keeping the tbi which is why i posted here.
Car: 82 El Camino
Engine: built 355
well right now i have a 92 rs with TBI, BUT im thinking about buying an 88 iroc with TPI, if you re read the post it says im THINKING about buying the iroc, thanks for your concern though, didnt mean to confuse anyone.
edit** im a jack ***, sorry about that, stupid me. Yes it will be tpi, again sorry about that
Car: 88 5.7 Iroc, 2000 SS
Engine: Vortec Hot cam TPI/LS1
Transmission: Pro-Built/T-56
Be careful with the rebuild, I had a crappy experience with a very reputable shop( obscure problem- hard for even an expert to diagnose). I tried to save a little $, cost me alot more in the end. Save for a good new crate engine if you plan on keeping the car. a bad rebuild can cost you twice as much as you plan on spending, plus a waranty is nice.
If you do rebuild, go to the local guy with the best rep/ references for machine work, assembly whatever- don't cutt corners in the wrong places. If you do it yourself, be **** on the tolerences ( Cam bearing, rod bearings, mains, balanced rotating assy,Head prep, bolts used, quality parts, right combination of parts - these are critical for a solid rebuild) Oh yeah - if you have alot of old sensors- factor that in as well....
If you just need transportation- slap it together - and pray it holds together...
My $.02
My $.02
Car: 82 El Camino
Engine: built 355
i dont really need transportation, ill be keeping my 92 also, i just want another iroc like my 1st car i had
mustangman65_79
Aug 11, 2015 03:17 PM
