Accell 24lbs injectors for 350 tpi?
Old Apr 18, 2004 | 12:39 AM
sst's Avatar
sst
I have a gm crate 350 tpi motor in my 89 T/A. The car originally had the 305 tpi engine. The car has the 305 injectors in it now. The mods i have for my car are Flowtec headers, k@n filter, airfoil. I was thinking of buying 24lbs accell injectors for my car. Will these injectors work ok with my car or should i go with the stock 22lbs injectors? I dont want to really get a prom made for my car so im hoping these injectors will work good as is. I have the 350 chip in my car also.
Old Apr 18, 2004 | 12:04 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
I'm running 24# Accel injectors on my 350 TPI (see signature).
I haven't had any injector-related problems in the 3 years I have been using them.
Hope this helps.
Old Apr 18, 2004 | 01:45 PM
Ragtop89's Avatar
I'm running them on my car.
I had some leaking o-rings on the injectors so I used stock GM o-rings and I haven't had a problem since.
That was 2 years ago.
Old Apr 18, 2004 | 07:00 PM
blackroc68's Avatar
YOU GUYS ARE LUCKY. My 24# accells only lasted 4 months and shorted out filling my brand new 383 vortec tpi with fuel. i hope my bearings arent damaged.
Old Apr 18, 2004 | 07:06 PM
wako29's Avatar
Car: '86 Caprice Classic
Transmission: TH-700, completely built
the 24lbs should work great for you, but I might suggest getting a chip made, but that really isn't NECESSARY until you do something thats pretty drastic like a cam or somethin. You are only losing about <10hp I would say with your mods, but you would lose a lot more if you put some fairly major power-adder to the car (boost, cam, heads, etc.)
Old Apr 18, 2004 | 08:45 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Definitely burn a chip for them or else you really won’t be getting the most out of them. I ran 24# injectors on a stock TPI (with a chip) and it was fine. I would suggest buying Ford injectors there cheaper and pretty much the same thing
Old Apr 18, 2004 | 10:48 PM
blackroc68's Avatar
Ford are better!!!!!!!!!!!!! :lala:
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
