FP Guage & FPR Q's...
Old Apr 27, 2004 | 04:41 PM
92GTA's Avatar
I'm looking to permanantly install a small analog fuel pressure guage into the schrader valve on my passenger side fuel rail.
I would like to get your guys suggestions on which brands are good, don't stand out too much, and which fit the space well. I also need to know exactly what fittings I will need to attach it.
I need the same advice for a fuel pressure regulator. I want one that is as easily accesable as possible and can be ajusted simple by and allen wrench or something similar.
Cost is not a considertion, I simply want the most precise and reliable parts available.
Thanks!
Old Apr 27, 2004 | 04:47 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I don't know about the gauge for the schraeder valve, but Holley makes an Adjustable Fuel Pressure Regulator that is easily accessable and adjusted by a hand **** on top.
Old Apr 27, 2004 | 05:12 PM
92GTA's Avatar
Well I found these 3:
http://store.summitracing.com/produc...earchtype=ecat
Which do you guys think is the best?
What about the guage? I can't find a single one either on Summit's site or Jegs...
Old Apr 27, 2004 | 05:28 PM
92GTA's Avatar
Ok, I like this exact guage:
http://store.summitracing.com/partde...t=SUM%2D800260
Now how exactly do I mount it right on top of the schrader valve? Exactly what parts do I need? I want to keep it as low down to the fuel rail as possible...
Old Apr 27, 2004 | 05:39 PM
pat12spe's Avatar
I bought a crane FPR and a holley FP gauge from Thunder racing. They were cheaper than Summit and Jeg's and I said I needed it shipped out quickly. The lady was very helpful and it arrived at my door 3 days later. I'm gonna install it this weekend, I'll let you know how it turns out.
Old Apr 27, 2004 | 05:46 PM
92GTA's Avatar
Well I found the regulator:
http://www.thunderracing.com/catalog...vid=6&pcid=164
But where's the guage you said you got? I can't find it on their site anywhere? no Biggie, I think I'll get the guage that I posted with the regulator you suggested. Now I just need to know how to attach the guage to the schrader valve...
Old Apr 27, 2004 | 06:21 PM
92GTA's Avatar
Ok, from reading other posts here and the specs for the guage on Summit's website, it looks like I need an adapter which is male -4AN on one side for going into the schrader valve, and then the other end of the adpater needs to be female 1/8NPT. It sounds like it will be a 1 piece fitting and I believe I found a picture of it in a nearby thread.
However it would also depend I'd think on how the back of the guage is setup as far as it's male 1/8NPT connector.
Does this sound right? Does anybody know how the back of that guage may be set up? Also where the heck would I buy an adapter like that? Am I on the right track?
Lastly, how does that Crane AFPR adjust?
Old Apr 28, 2004 | 03:56 PM
pat12spe's Avatar
http://www.thunderracing.com/catalog...3&sid=273#P988
Here's the link to the gauge. Don't try and make your own when it's cheap to get one already designed for our vehicle.
Old May 2, 2004 | 03:10 AM
transambill's Avatar
Car: 91 Firebird Formula
Engine: ZZ4 fast burn with TPIS mini ram.
Transmission: Viper T10 6 spd.
I use the Accel guage part #Acc-74745. Comes with all the fittings you need to attach it to your schrader valve.
It's suppose to not be permantly mounted/for test purposes only but I've had it on my car for almost a year and no problems whatsoever.
sheachopper
Jul 31, 2019 11:27 AM
tmellott89
Oct 14, 2015 02:06 PM
