won't start
Old Apr 30, 2004 | 12:44 AM
i885744's Avatar
Car: 73' vette stingray
Engine: 385inch stroker
Transmission: muncie 4 speed
won't start
I"m retrofitting a 78 with tuned port injection off of an 87 camaro, with mass air. The motor is chevy's 350cid crate motor, I've got the tpi all hooked up ready to go using the painless wiring harness. The car turns over, i'm getting pleanty of spark, getting pleantly of fuel to the rail, 45psi. Using accel 24# injectors for a 350, brand new. Also using the hypertech chip. The car cranks fine, and fires a few times, but just won't get going. It cranks and fires and spits a few times, but won't stay alive. I'm getting code 12 out of the computer, nothing else. Any ideas? Thanks, Mike
Old May 1, 2004 | 11:29 AM
redrummer's Avatar
Car: '88 Trans Am GTA
Engine: 5.7L L98
Axle/Gears: 3.27 Aussie 9 Bolt
Code 12 just means you're communicating with the computer.
Mine's doing the same thing as yours. However, I'm not getting any spark past the distributor cap. I think something's still buggered up with my wiring. I'm not throwing any codes or anything.
Old May 2, 2004 | 10:33 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
Sounds like you might have the distributor in 180 degrees backwards. You would still get spark but the firing order would be off and it would just run for a second and die.
Old May 2, 2004 | 11:21 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
First Adjustments
Make sure you reset the TPS and the timing.
I was going through the same tye of startup last week.
The timing light (and a new module for the Distributor) showed me the way.
I used some starting fluid to determine if it was fuel related, it wasn't.
I was flooding but "thought" I had the spark right.
After putting in the new module it still had trouble running.
A reset of the timing to where I knew I was straight up at TDC, it fired right up.
Good luck.
Derick15
Sep 17, 2016 05:28 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
EFR2000
Aug 18, 2015 08:54 PM
