305 TPI 1/4 times
Old May 2, 2004 | 06:01 PM
ghettosmurf's Avatar
Car: 89 Camaro
Transmission: A4
305 TPI 1/4 times
Is it possible to get a 305 TPI to run low 12's??? I heard taht someone in here (cant remember his name) had one that does. I was going to get some SLP siamesed runners, different base (didnt know what kind), someone told me to get like the TPIS manifold cuz they said the HSR and TPIS system were to big for the 305. different heads, cam, hooker headers w/duals all the way back, full suspension set up and weighing about 3400 lbs. with driver. what numbers can i expect with these mods and what else can i do? i didnt want to do any NOS or supercharger yet...but the supercharger is in mind for a later day
Old May 2, 2004 | 06:08 PM
Car: 89 Camaro
Transmission: A4
oh also plus a aluminum drive shaft...3.42 gears w/posi...shift kit and drag radials
Old May 3, 2004 | 12:09 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Do all the mods that you mentioned and I think it could be done. If it's an automatic, get a torque convertor.
Old Aug 21, 2012 | 08:42 PM
haisud's Avatar
Re: 305 TPI 1/4 times
stock 305tpi 2.73 posi with procharger what 1/4 time ?
Old Aug 21, 2012 | 09:21 PM
Jason C. Laney's Avatar
Car: '90 rs
Engine: 305 tbi for now
Axle/Gears: stock rear for now
hard to say. tons of factors and variables, but with a 2.73 rear, i wouldn't expect much. 15's MAYBE high 14's but i wouldn't bet on it.
Old Aug 21, 2012 | 09:46 PM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
After having a bunch of TPI 305s back in the day i can say a manual conversion is the best source of power!
91Z28 Lb9, 700r4,2600stall, 3.42 posi rear, headers full exhaust,K&Ns w/cut airboxes, pulleys,custom chip would run consistant 14.4s converted to a 5spd same car would run 13.5 at HRP
89TA Lb9, 5spd,3.08,headers,full exhaust, pulleys, custom cold air. would run 15.40 best pass. Converted to L98 and 3.27 9bolt would run 13.7
Old Aug 21, 2012 | 10:40 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Doubtful
Old Aug 22, 2012 | 12:05 AM
IrocRoadRacer's Avatar
Car: 1989 Camaro Iroc Z
Axle/Gears: 9 Bolt Borg Warner/ 2.77 gear
A stock LB9 can safely run 10psi of boost while a stock L98 could do 8 psi.
When I had my supercharger on my 89 305 tpi, I could have easily done a low 14 sec quarter mile.
Old Aug 22, 2012 | 12:06 AM
It would take a lot of money to get a 305 running 12's
BlueIroc-Z
Jun 9, 2019 03:22 AM
Brcharrelson
Aug 26, 2015 07:47 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
