Anything to be gained w/AFPR on stock 305 tpi
Old May 7, 2004 | 12:41 PM
gifman's Avatar
Car: 91 Formula
Anything to be gained by putting an adjustable regulator on a stock 305? Several publications talk about 15-20 hp gains simply by going from 40 psi to 46-48psi. But I've also read/heard where people end up running there best times with the pressure dialed right back to the factory setting (40psi?) ???
Also, will this shorten the life of the injectors or fuel pump?
Lastly, can the factory fuel pump handle the increased volume?
Gifman
Old May 7, 2004 | 12:50 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
I think the only gains from it would be gained if you are currently running lean.
jaridjohn
Jul 8, 2024 03:49 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
marcusaw
Aug 10, 2015 08:13 AM
