injector size question
Old May 8, 2004 | 06:04 PM
Notplayn's Avatar
Car: Depends on the day!
Engine: the kind that runs on money
Transmission: One that holds up, I hope
I have a 89 GTA w a 350. I have a mild upgraded cam, mild upgraded torque converter. I will be installing headers. No head work at this time. Adj fuel pressure reg is installed. Should I go back with 22# or 24# injectors. The computer has not been changed. Thanks
Old May 8, 2004 | 07:23 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
depends on what you want to do with the engine later on. Bigger cam, Better heads, ECT. I would say at Least 24# but give it a minute and some one else will say go with 30# SVO's
or something else.
Old May 8, 2004 | 07:53 PM
Notplayn's Avatar
No major changes any time soon..
Old May 8, 2004 | 07:55 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
just stay with the 22# injectors.
Old May 10, 2004 | 03:26 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
I agree on the 22# injectors, you should need lots of mods to get any benefit from the 24's, and especially the 30's.
Old May 10, 2004 | 04:21 PM
Notplayn's Avatar
I agree on the 22s- Where can I find them? thanks...
Old May 10, 2004 | 04:29 PM
vernw's Avatar
Probably any local parts shop, or if you're not in a hurry, eBay or Jegs or Summit. Summit or Jegs will probably be the cheapest.
Old May 10, 2004 | 06:09 PM
Notplayn's Avatar
I spoke with JEGs this morning. They dont carry them. Only 21s or 23s. The svo 23s were a ev6 (something like that) which are smaller than the 24s which were ev1 (something like that).
Old May 10, 2004 | 08:22 PM
DJP87Z28's Avatar
Gmpartsdirect for the stock factory 22# ones, not exactlly cheap.
Old May 11, 2004 | 02:11 AM
89FormulaRoth's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7L TPI
Axle/Gears: Borg Warner 3.27
Get the Bosch 0280150561 D9B-22lb* set for TPI from www.fiveomotorsport.com for 8/Set: $188. They are the ones with the black body and pink tip. These are the ones I'm likely going to buy.
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
knight72
Aug 10, 2015 09:32 PM
