I need a efi definition
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Re: I need a efi definition
Originally posted by RobCan
please help car is not running right thanks
Who ever would have thought?
Seriously though...more info needed here...
Engine: LS3
Transmission: 6L80E
This must be a joke, right? I would assume so since you only have 6 posts...and/or a learning disability.
If you have a problem and want help, state the facts...
Car: 89 IrocZ
Engine: L98-ish
I'll give him the benefit of the doubt.
If you're referring to the Throttle Position Sensor(TPS), or the Idle Air Control(IAC) or even minimum idle speed, all can be found on the home page at www.thirdgen.org Tech Central...look through the Tech Articles.
Good luck.
Good luck.
