1988 Iroc Stock Needs Upgraded
Old May 20, 2004 | 03:00 PM
tjl IROC's Avatar
Car: too many
Engine: SBC
Transmission: AUTOs and a 5 speed :D
Axle/Gears: you name it
I have a tpi 305 1988 IROC Z
I need more power all around
can anyone tell me the best mods I can get at reasonable price?
All I have so far is a new shifter
Air foil?
KN Air filters?
Headers?
Exhaust?
MSD stuff?
Chip?
NOS? what size shot won't hurt my engine?
or does any one no where I can get a reasonable priced new or used supercharger?
Old May 20, 2004 | 03:55 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Cut off the bottoms of your airboxes, and get K&Ns.
Headers, !cats or aftermarket cats, catback exhaust.
You'll feel a big difference after that very basic stuff.
Old May 21, 2004 | 06:33 AM
speed88's Avatar
Car: 1988 Trans Am GTA
Engine: 383
I agree!!
Free mods, listed here on this website, and a set of underdrive pulleys would also be a nice improvement. Is your car a auto? If it is a Torque Converter is worth it's weight in gold!!
Old May 21, 2004 | 09:15 AM
tjl IROC's Avatar
Car: too many
Engine: SBC
what do you mean about opening my car's airboxes?
Old May 21, 2004 | 01:58 PM
smithtc's Avatar
Welcome to the board!
Try these links to help get you started.
https://www.thirdgen.org/newdesign/tech/
https://www.thirdgen.org/newdesign/tech/mods2.shtml
https://www.thirdgen.org/newdesign/tech/tpimod1.shtml
https://www.thirdgen.org/newdesign/tech/ramair.shtml
Old May 21, 2004 | 03:30 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Take off your airlid - the Y shaped plastic at front of engine bay with the six twist-lock tabs.
Underneath, take off the two filters. See that garbage there? That is nothing but plastic restricting the filters access to air.
You can eaily unscrew the lower air box housing and cut off all of that stuff right underneath the lip of where the filter sits.
Should have been that way from factory!!
Old May 24, 2004 | 09:04 AM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
bad *** thanx for that info guys i just got my self an 86 iroc-Z with a 305 TPI engine... its auto with a hurst shift kit and a hyper tech performance chip... i think im going to go give that air box mod a try. ill post back with any performance inhance i feel. also what other small things can be doen to these 305 tpi engines to open them up a bit.
Old May 24, 2004 | 11:27 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
What has already been mentioned is common law... beyond that you can do the typical first stage of weight loss: remove backseats and bolts, remove seat belt retractors and bolts, remove spare and jack. All told about 75lbs worth of junk or about 6 or 7 RWHP equivalent.
Also, gearing and a torque converter will make a huge difference! A slightly looser aftermarket converter and the next step lower in gearing will wake that b**ch up off the line!
Old May 24, 2004 | 09:53 PM
tjl IROC's Avatar
Car: too many
Engine: SBC
this is all very interesting
Im going to try to modify my airbox this week
does adding a jet chip help ?
some of my friends told me its a waist of money?
Old May 25, 2004 | 12:23 AM
Abubaca's Avatar
Don't mess with a chip. Not a brand name aftermarket chip anyway. There are a few people like Ed Wright at Fastchips, and a few others than program chips that are actually worth anything, but don't mess with Hypertech or Jet, or anything like that. To truly burn a chip properly, your car needs to be present, and it's gonna take more than one chip to get it right. You can learn how to do it yourself, and the cost of the equipment is about the same as a good chip that someone would burn for you. I'm not gonna suggest doing it yourself though,it takes quite a bit of time and experience, but if you're up to it, it can be done!
Don't take that the wrong way though. Some of these guys here at TGO know engines inside and out, and programming their own chips is just the next logical step. I myself am just starting to understand how all the different systems work together, and how they effect performance. I am not at the point where I feel that I can really learn how to effectively burn my own chips. (yet). If you feel you're up to it, I say go for it!!
gta90
Sep 15, 2015 04:00 PM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
kyleb24
Aug 15, 2015 08:24 AM
Randomtask2
Aug 13, 2015 01:57 AM
mustangman65_79
Aug 11, 2015 03:17 PM
