cold air intake
Old May 23, 2004 | 11:10 PM
purplebird's Avatar
Car: 1992 firdbird formula
Engine: 5.7 tpi
cold air intake
Where is the best place to buy a cold air intake for a 1992 firebird. Which one is best. Thanks a lot
Old May 24, 2004 | 12:55 PM
84Grn's Avatar
Car: 84 Pontiac Firebird
Engine: 368 6.0 LS
Transmission: 350 turbo+tci 3000 stall
Axle/Gears: 10 bolt 7.5 with 3.73 auburn posi-t
I tried it before and it seems like there's no aftermarket cold air kit for 89-92 year model. Looks like it will have to be custom make to have one. I have an idea get a steel pipe from a muffler shop I think it's 3 and half inches pipe and have it bend slightly then cut up a hole under the old air filter box to get into the fender and add cone to it. Seems like a best solution to get a cold air charge into the engine? It's just a thought
Old May 24, 2004 | 04:18 PM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
I'm pretty sure SLP makes one. But at over $200 I would make your own.
Old May 24, 2004 | 07:28 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I bought the Cold Air Kit from SLP years ago for my 1989 Trans Am. I don't know if you can still buy them. Allen
Old May 24, 2004 | 07:31 PM
Kwik89GTA's Avatar
Car: 1989 Bright Red GTA
Engine: Grand Sport LT4
Axle/Gears: 10 bolt 3.73
SLP makes a Cold Air Intake (www.slponline.com) for all years of TPI cars, MAF and SD. They move the charcoal canister underneath and take fresh cold air from the passenger side fenderwell. SLP also makes a dual inlet cold air sytem for SD cars, but you will have to relocate your battery to the trunk.
Old May 24, 2004 | 09:23 PM
TheMysticWizard's Avatar
Car: 1987 Firebird Trans AM
Engine: 383 TPI...very soon
Transmission: TH700R4
Heads up.. I just went with a friend to get a SMOG Pre-test, and they told him he would fail the visual, because he relocated the Charcoal Canister, and added a SLP Cold Air Intake. SLP's website says it is legal, and has CARB numbers, but the smog tech said it couldn't pass with that CAI because the charcoal canister had been moved. The SMOG Tech also said the Throttle Body Bypass would fail the visual too... I'm just getting the word out, as I have seen this first hand now. I was wondering if anyone else had any other information about SMOG and CAI in California.
I was going to build a custom CAI but now I'm scared. I wanted to relocate the Charcoal Canister to somewhere in the front of the nose, but now I don't think this is possible to do and still pass SMOG.
Old May 24, 2004 | 09:47 PM
Car: 1989 GTA
Engine: 369 TPI
I had to go to a Test Only smog station here in Southern California this past January. With the SLP Cold Air Intake I to had to have the charcoal canistor relocated. Also had the throttle body bypass. No problem where I went. He asked about the bypass and I told him it was for cold weather to keep from icing. In SoCal we don't need it.
By the way I barely passed the emissions test. My car is at Dyno Don's here in SoCal getting an upgrade at the present time including the exhaust system. Come to find out one of my cats was complete gutted. The other was just fine. Also the air pipes to my cats were partially broken and leaking air.
I'am just amazed that it passed the smog test. Allen
Old May 24, 2004 | 10:07 PM
I have to go to a test only for smog, they randomly chose me to go... wonderful news when I opened the renewal notice. Where did you relocate your Charcoal Canister to? I am hoping when I go to the Test Only Station, that the guy is cool... but I already seen one smog tech in action, and that was at a regular station.
The regular tech said that the Throttle Body Coolant Passage was to "COOL" the throttle body, because it normally gets very hot, and the coolant helps keep it cooler. My friend and I both knew that was BS, but then he said that it is part of emissions, and it would have to be fixed before being smogged again.
Old May 24, 2004 | 10:19 PM
Car: 1989 GTA
Engine: 369 TPI
My charcoal canister is next to the battery on the drivers side. My battery has a strap that makes it easy to get in and out. With out the strap the charcoal canister makes it hard to get the battery in and out unless you remove the canister. Allen
Old May 24, 2004 | 10:33 PM
Enough space on the boards.. you have a PM.
Old May 25, 2004 | 09:54 AM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
Man where was that station at MYstic? They are being hard azzes. I think it all comes down to where you go. So we should have a list of smog stations to avoid set up for different areas to help us avoid this problem.
If you make your own CAI, you can do it without removing the smog canister.
Old May 25, 2004 | 10:48 AM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
I have had my car smogged several times. The Throttle body coolant has never been hooked up. It is also not on the list of things for the smog tech to verify is present and working. I also re-routed and re-engineered my AIR system, and have had no problems.
Go to a different smog station. He is not being reasonable, as there are no laws that say you can't move things. They just have to be present and operational.
Troy
So Cal
Old May 25, 2004 | 11:18 AM
I wasn't planning on removing the Charcoal Canister, I was just going to move it, I was thinking somewhere inside the nose.
This Smog Station was on the corner of Dyer Street, and Alvarado Blvd, in Union City... The 76 Station right there. I will not be going there for any SMOG tests.. that's for sure.
Troy
So Cal
It clearly depends on where you go, because I have seen MANY MANY people move things around, and have no trouble with smog. This guy was just pointing everything out, anything that didn't look stock, he said needed to be changed. I was astonished as he started naming things off... It didn't make sense, I mean as long as it's hooked up and working, who cares where it is.
But I also believe they should do away with Visuals... I mean if you pass the sniffer, who cares what's hooked up and what is actually there. Right? I don't get it, these laws seem to be getting more abserd every day.
Old May 25, 2004 | 12:12 PM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
"But I also believe they should do away with Visuals... I mean if you pass the sniffer, who cares what's hooked up and what is actually there. Right? I don't get it, these laws seem to be getting more abserd every day."
Ditto!!!
Old May 25, 2004 | 02:00 PM
PsychoGTA's Avatar
Dude that really sux. That guy was probally a mustang owner and is a f-body hater. If you see him again you should tell him to take the stick out of his a **.
Peace Out,
PsychoGTA
Old May 25, 2004 | 02:49 PM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
it was my car that failed the visual that mystic was talking about. . i wanted to shoot him in his piehole
Old May 25, 2004 | 02:58 PM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
Hey was it a pre-inspection? If he didn't punch you into his database I would just find a different shop. Go to one that isn't so high profile there less likely to give you crap.
Old May 25, 2004 | 03:04 PM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
it was a pre-test, and i also barely failed emissions. . Since i have a miss in the engine, i believe that was the cause of it.
Old May 28, 2004 | 11:51 PM
MikeS's Avatar
Purple,
If I were you, I'd try searching for some info on the SLP airbox. If I'm not mistaken, you can buy just the airbox for around $80 from SLP and use the rest of the stock intake tubing (on later thirdgen firebirds). On earlier TPI birds like my 87, I'd either have to buy the full kit, or pick up some intake ducts from a junkyard to go with the airbox.
Hopefully somebody more knowledgable on this topic will add some information, maybe somebody who's got the SLP airbox...
Old May 29, 2004 | 01:23 PM
vteccoupe's Avatar
Car: 85 T/A
Engine: 305 tpi
just put it back to stock for emmisions, and put it back on after. thank *** there is NO emmisions where i live, they might have a problem with no cat on it. as for a CAI, i just took a K & N cone filter and straped it straight on to the mass air. the canister and overflow droped right back in.
Old May 29, 2004 | 04:46 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Hard to tell if that's sarcasm or happiness, lol. But if you're worried, don't be. Test Only stations benefit older cars, which yours is and which is why it got chosen. They're there to make sure older cars get a fair test.
A Test Only center does no repair work, and they can't(not supposed to) recommend a shop that does. So they have no financial interest(or kick-back) by an older car failing--unlike a smog test station that also does repair work.
So if you own an older car, which you(we) do, stations that do repair work "see you coming," so-to-speak, and some have been known to wrongly fail cars and hit people up with bills for a lot of bogus repairs just to make money.
Test Only stations are a good thing!
1992 Trans Am
May 10, 2023 07:19 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
stalkier
Dec 6, 2015 11:25 PM
hayesaw0210
Aug 23, 2015 11:15 PM
kyle5647
Aug 15, 2015 11:56 PM
