Need EGR Help
Old May 31, 2004 | 04:10 PM
Syxx613's Avatar
Car: 1987 Trans Am GTA
Transmission: 700 R-4
Need EGR Help
i took off my plenum today to try and solve my EGR problem. However i found a new one when i couldnt even remove the EGR itself, lol. i accidentaly broke the porcelain piece going into it and the wire fell out and then i couldnt get enuff room to get the 2 bolts out. im kinda stuck and need some help. also can i get the part i broke from Auto Zone? thanks!
Old Jun 1, 2004 | 02:43 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Try harder to get the bolts out. Between a 10mm wrench and a shallow 1/4" socket you should be able to get it out without removing the runners.
If not, go buy a cheap 10mm wrench, stick it in a vice, heat it, and bend it to around 45* right near the closed end. Then you'll have plenty of room to get it out. You'll also find that this new tool works very good when trying to install or remove the tv cable bolt from the outside of your transmission.
Old Jun 1, 2004 | 04:33 PM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
Did you actually break the porcelean piece or just unscrew the top part of it with the wire? A socket isn't going to work so you need a small box wrench, you should be able to get at it with that without heating and bending.
Old Jun 1, 2004 | 08:12 PM
TheMysticWizard's Avatar
Car: 1987 Firebird Trans AM
Engine: 383 TPI...very soon
Transmission: TH700R4
I used one of those Ratcheting Wrenches on mine, worked like a charm... I started out with a open end wrench and rounded the bolts off, so I decided something else was needed. Mine wern't 10mm tho... hmm, I think they were 7/16. I also broke the ceramic thing off the EGR, but I was switching EGRs, I had another used EGR with the sensor on it.
You'll get it... It's just gonna be fun.
Old Jun 1, 2004 | 09:47 PM
Syxx613's Avatar
i actually BROKE the porcellain, lol. can i get that replaced from AZ or something? i hope so cuz if not im screwed! lol. anyways, i got the front bolt off of the EGR but not the one closest to the firewall, i cant get in there with the tools i have. i tried getting the runners off, but couldnt get the drivers side off even after taking out all the bolts i could find for it? well ill get at it tonight hopefully and let u guys know how it goes!
Old Jun 1, 2004 | 10:14 PM
I would imagine you could get a new one from Autozone or something, if not, off to the junk yard I guess...
The runners have a bolt that goes from the opposite side, I believe it's in the back by the distributor on the drivers side, Can't really remember. Just look around the bottom of them on both sides, if you didn't get that one from the inside, then that's probably the problem.
Goodluck
Old Jun 1, 2004 | 10:42 PM
Syxx613's Avatar
well it turns out all i had to do was hold a little 10 mm wrench with a vice and beat it down till it bent at the right angle, i got in there without removing the runners and got the EGR off! i tested it and it is VERY hard to push the diapraghm in. does that mean that its bad? also its very dirty. thanks all!
Old Jun 2, 2004 | 09:12 AM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
Hard is a relative term, I know the springs on those are pretty strong, they do not move easily. If your car has alot of miles you might as well replace it while your there. Do you have a pic of the porcelean piece you broke? I actually thought I broke mine. The very top had come loose and seperated from the rest of the shaft, but looking closely, the top threads into the shaft so I think I am OK, unless its threaded in and then sealed over.
Old Jun 2, 2004 | 10:20 AM
Syxx613's Avatar
well i guess ill just buy a new EGR. but it will probably take forever since my AZ never has parts for our cars. no i really BROKE the porcelain, it shattered! well thanks!
Old Jun 2, 2004 | 10:50 AM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
Auto Zone had mine in stock $50.00. You might get lucky because the same EGR is used on other vehicles also, it is not unique to our cars.
Old Jun 2, 2004 | 11:35 AM
Jim85IROC's Avatar
Told ya.
The porcelain piece that you broke is part of a sensor that is available separately. I don't think a new EGR valve comes with one, although I could be incorrect.
Old Jun 2, 2004 | 11:53 AM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
The EGR does not come with that sensor, it would be a seperate piece.
Old Jun 4, 2004 | 04:44 AM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
that is the egr temperature sensor that white stuff is only a protector of the wire just as long as the metal part of the wire goes down inside the bolt it should be fine....be sure to check the type of egr valve there are 3 types negative pressure positive pressure and universal.....if you buy standard it is actually the exact one produced by gm (rochester) but standard buys them and puts them in a new box.....to figure out what type of egr you have after all the numbers there is a letter N or negative, P for positive or no letter . make sure it is correct or it will not match....and to get the runners off you have to remove the valve covers and there is a hidden bolt. on the very bottom.... AND REPLACE THE GASKETS might as well remove the runners your this far and the gasket comes as a whole set... lower and upper. plenium and throttle body.
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
meeklay812
Oct 1, 2015 03:46 PM
