4 - 7 Swap Camshaft
Old Jun 8, 2004 | 07:47 PM
TPIJeep's Avatar
Engine: 7.4 L of Small Block Fun...
4 - 7 Swap Camshaft
I tried searching for this topic so if its been covered before I am sorry.
Has anybody used a 4-7 swap cam on a TPI motor? What were your results.. I plan to dyno the new motor I am building but I just wanted to know what kind of increases or benefits I can expect.
I am working on a 454 Small block, Stealth Ram, Gen7 box, AFR 210 heads about 9:8:1.
Thanks,
Mark
Old Jun 8, 2004 | 11:41 PM
bo ty guy's Avatar
Car: 92 Grey-Green B4C
Engine: mini-rammed 383
Transmission: Tremec TKO
Post your results. My buddy is building a combo very close to your own. He is considering a 4,7 swap himself. Good luck
Old Jun 10, 2004 | 12:13 PM
myfast3rdgen's Avatar
Car: Trans Am
Engine: 305 to 350 to 383 to BOOM!!!
Transmission: 5-speed
Axle/Gears: 3.73 10-bolt
I was thinking of that myself, but I heard that it can not be done on a TPI because of the way the computer and injectors are set up, I never exactly seen it done, but thats not to say that it cannot be done, i'm sure your going to have to burn a new chip so the computer knows what your eninge is doing.
I never really looked any further then that i'm not too much into the computer aspect of the car, if it works please post it becasue I like to see if it works and what horsepower gains you get.
Old Jun 10, 2004 | 02:07 PM
Guest
Guest
Posts: n/a
The computer wont know the difference.
Old Jun 10, 2004 | 02:21 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
what is a 4-7 cam swap
Old Jun 10, 2004 | 02:35 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Re: 4 - 7 Swap Camshaft
you swap the firing order around and 4 and 7 switch places.
TPI is batch fire. it doesnt know. it doesnt care. it works fine.
Thanks,
Mark
i have yet to see or hear of any gains that can be directly attributed to the 4-7 cam... but i dont hang out with circle track guys.. and they're the ones that do it the most from what i understand.
it wont hurt, but will it help? i dont know if you'll see any gain.
if you really are Mr moneybags though, try a identical cam profiles, one swapped one not and post your results. i would be intrested in that
Old Jun 10, 2004 | 05:51 PM
DFI79MC's Avatar
Car: 79 Monte Carlo
Engine: 406
Transmission: 2004-R
Axle/Gears: Phord 9 inch/3.90
As I understand, the 4-7 swap cam is designed for, and only effective on intake manifolds with shared runners (single plane).
Old Jun 10, 2004 | 06:16 PM
TPIJeep's Avatar
That was my understanding also about a single plane manifold but I also heard it helped with crankshaft deflection and harmonics..
I will have this on my Superflow dyno and can test different cams.. just not sure if its worth the money to buy 2 cams with the same profile, one regular one with the 4 7 swap, maybe COMP will help me out with this test.
We just put one in a stocker class motor and it has a much flatter and longer torque band over other motors we have done with the same setup, so that is one plus.
A Alky drag motor we did also had a flat torque band with the 4-7 swap, I am just looking for outside input before I invest the extra cash.
Old Jun 10, 2004 | 06:31 PM
83 Crossfire TA's Avatar
Re: Re: 4 - 7 Swap Camshaft
Even if you were using a sequential setup it would be easy enough to just swap injector connections.
I doubt that you’ll see a measurable difference on a TPI. Between the long runner/plenum setup and the relatively low hp and not much rpm, you’ve pretty much done everything you can to hide/mask any breathing and harmonic effects that you’ll get. I’d be very surprised if you could document more then 5hp difference.
Old Jun 12, 2004 | 11:29 AM
Car: Trans Am
When GM designed there Small Blocks they had the idea of the motor running smoothly. When you switch the 4&7 its has to something with which pistons are at TDC and so by switching it you can notice a 15 HP gain by just switching the cam itsleve, no change in lift or duratoin. I have an old maginze that i found that i read that in.
Old Jun 12, 2004 | 01:51 PM
vampiroc's Avatar
Car: Z28
is that at the wheels or at the crank?
Old Jun 12, 2004 | 03:25 PM
Car: Trans Am
it didn't say
i'm guessing at the crank
Old Jun 12, 2004 | 06:51 PM
TPIJeep's Avatar
We did some more dynoing with a std and 4-7 swap cam, very similar duration within 3* of each other and same lift at the valve. The rules for this class are very specific so they both run junk *** 441 casting # heads, 175 of cranking compresion, stock 4 bbl intake, 4 valve relief flattops nothing special at all. The only difference between the two is a Double roller timing chain on the std cam and a wet belt drive on the 4-7 swap. The std cam made 344hp at 5700 and 371 ft/lbs, the 4-7 swap cam made 372 hp at 5900 and the same torque. The 4-7 swap cam seems to hold its torque much better then the std even though the intake and heads are the same, I can see the belt drive freeing up 5 hp or so from this one test I am seeing 23 hp gain from the swap.
I think I am going to go with the 4-7 cam on my motor and add roller cam bearings just for the heck of it, a wet belt system would be a nice touch but for the raised cam block an extra 800 bills is not in the budget!..
Old Jun 13, 2004 | 05:33 AM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
Just curious.... Does that 4-7 swap change the sound in any way?
Old Jun 13, 2004 | 07:57 AM
TPIJeep's Avatar
Not that I can tell on the dyno, in a car on the road or side by side another car it may. When we get these in their cars we will know for sure.
gta90
Sep 15, 2015 04:00 PM
blackroc68
Sep 1, 2015 08:01 PM
midge54
Aug 29, 2015 09:51 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Jake_92RS
Aug 17, 2015 09:42 AM
