Stockish l98 cam selection
Old Jun 11, 2004 | 02:44 PM
92HeritageZ28's Avatar
Car: 1992 Heritage Z28
Engine: 5.7l TPI
Transmission: A4
Im sure this has been asked before, but the search page keeps bringing up a page saying server unavailable when i try to use it. I have a 92l98 bone stock except for a flowmaster 80 series and a cutout before it. I have to replace the intake gasket due to leakage and would like to change the cam out while i have it all apart. I also plan on porting the base and plenum and maybe try to clean out the heads a little. The car will most likely never see anything more other than some shorty headers in the future. What would be a good cam for this combo? I think it will hit low 14's as it sits, so i would like to break 13's. Ive beat 2 lt1 ta 6 speeds and pulled them to 100mph so i think i have a fairly fast one. I also would like a throatier sounding muffler. any suggestions? I usually leave the cutout open all the time now because the muffler is too quiet and i still get drowned out by any ls1 with aftermarket exhaust(although im sure headers would help). Is it really worth it to spend all the extra money for a full cat-back system or is just the muffler a better choice.
edit: I forgot to say that the cam needs to work with the stock tuning(even if tuning would improve performance)
Old Jun 11, 2004 | 05:09 PM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
Id say a ZZ4 cam, can be had on ebay for 130 ish, or LT4 cam.
Old Jun 12, 2004 | 12:16 PM
Engine: 5.7l TPI
Transmission: A4
if i go with the zz4 cam, is there anything else i have to replace besides the cam?
Old Jun 12, 2004 | 12:25 PM
Engine: 383, L69
Look at Comp 986 with the correct retainers and stuff.
Also gonna have to check with retainer to valve guide clearance.
Old Jun 12, 2004 | 12:44 PM
CashMunson's Avatar
Car: 87 Trans Am GTA
Engine: 408 LS
Transmission: LS 4L60E
Axle/Gears: 9 Bolt/3.70 Gears/TAP Girdle
92HeritageZ28 I sent you a pm.
Jorlain
Oct 8, 2015 01:57 AM
scottmoyer
Sep 7, 2015 07:06 PM
Strick1
Sep 4, 2015 07:11 AM
Formula_88AE
Sep 3, 2015 01:47 PM
z28guy134
Sep 1, 2015 11:50 PM
