throttle sticking?
Old Jun 20, 2004 | 04:31 PM
trueburton's Avatar
Car: '88 Red Trans Am w/ T-tops
throttle sticking?
my throttle likes to stick at about 2000 rpms but only when the car is running. it moves freely when the car is off, but when car is running it will get stuck. Any ideas?
Old Jun 20, 2004 | 04:40 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
happens all the time, especially just after cleaning. Lubricate it. The old/worn bushings have slop that allows easy movement when the engine is off, but engine vacuum bends the shaft a tad, and it binds the shaft and causes the sticking.
I was in a pinch and used WD40, and it's been working for months. Do a search for what is most recommended I guess.
Old Jun 20, 2004 | 05:26 PM
trueburton's Avatar
i cleaned it a long time ago thiinkin that it was gummed up with carbon but never lubbed it afterwards. i then cleaned it again recently because i thought it was gummed up again but now it started to get worse and stick at higher rpms. i'll lube her up tonight (no pun intended) and seee how she drives. thanks alot.
Old Jun 20, 2004 | 09:23 PM
trueburton's Avatar
well i lubed her up tonight and it didn't stick anymore. I'll prolly run a second return spring just for ensurance. thanks for the help.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
DiabloWS6
20
Dec 11, 2015 04:12 PM
Scorched1984
Sep 15, 2015 03:42 PM
banksGTA
Sep 13, 2015 11:56 AM
Randomtask2
Sep 7, 2015 05:06 PM
