Intermittant Code 36, est? maf burn off?
Old Jul 6, 2004 | 01:45 PM
Stan's Avatar
Car: '87 IROC Z28
Engine: 350 HO 330 GM
Transmission: 700r-4
Or, could it be a dirty air filter? I charged the KN filter and she seems to be more responsive....I also switched from 93 octane to 89....could this be the culprit?
Stan
Old Jul 6, 2004 | 05:59 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It could also be a poor connection at one of the relays.
Old Jul 6, 2004 | 09:28 PM
Guest
Guest
Posts: n/a
I've heard of people setting code 36's after getting a bit happy with the oil on the K+N.
A weak starting voltage can also set a code 36.
Old Jul 7, 2004 | 05:40 AM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
I had the same thing this winter, I unplugged and replugged the maf in and it has gone away.
It wouldnt be the gas, only air flows through the maf anyways
Old Jul 7, 2004 | 08:03 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Bad oil pressure switch...........
Search! and you will find alot of info abot code 36...........
/N.
Old Jul 8, 2004 | 10:56 PM
89PONT.FORM's Avatar
Car: 89 FORMULA
Engine: 305 T.P.I.
est
hey guys i need help my engine ligt came on so i pulled some codes and it turned out to b code 42 which is *est* what the hell is that?
Old Jul 8, 2004 | 11:03 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Electronic Spark Timing, do a and you will find the trouble shooting chart I have posted numerous times that will help you get started with the problem.
Old Jul 10, 2005 | 05:43 AM
Blackbari's Avatar
Car: 1988 IROC
Engine: B2L
Transmission: MD8
Axle/Gears: 2.77 9 Bolt
Read my post
After a long battle with my car, here is what solved my Code 36:
My code 36 solved
db057
Apr 28, 2019 07:45 AM
BumpaD82
Feb 26, 2016 02:57 PM
85 Jimmy
Sep 30, 2015 07:56 AM
3rdgenkindagal
Sep 13, 2015 02:02 PM
