What injectors for a ZZ4?
Old Jul 13, 2004 | 10:06 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Hey my dad needs new injectors for the 90 Formula. The specs are
ZZ4 Crate
1 5/8 inch Edelbrock headers+y-pipe
3 inch American Thunder Catback
SLP Runners
Lingenfelter intake
B&M Flexplate
Stock 700R4
2.73 Rear
He just got a set of Venom injectors in the mail, but the injectors were tossed in a box and shipped. He's going to send them back to Summit.
Old Jul 14, 2004 | 09:55 AM
ULTM8Z's Avatar
24 #/hr. That's what I'm running with my setup. They'll support up to about 400 hp.
Old Jul 14, 2004 | 10:42 AM
Ragtop89's Avatar
400 hp easily.
You should have no probs with a 24lb/hr injector.
Old Jul 14, 2004 | 12:23 PM
chevyengr's Avatar
Car: 1990 IROC-Z 350Stealthram 11.61@120
Engine: 350 Stock Bore&Stroke
Transmission: 700R4 Auto/Vigilante 2600
Axle/Gears: 3.42 Stock 10 bolt
That's what I am using! Ford SVO 24lb'ers.
Old Jul 14, 2004 | 09:26 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
What type of brand do you guys suggest? My dad wants 30 lbs injectors because that is what Summit suggested.
Old Jul 15, 2004 | 06:27 AM
chevyengr's Avatar
I am using the SVO Ford Motorsport blue 24lbers. You can get a set rather cheap-- new. Or you can usually find some for sell for around 100 bucks or less -- on the classified boars.
Old Jul 15, 2004 | 01:29 PM
ULTM8Z's Avatar
I'm also running the SVO injectors. Got them from Summit.
Old Jul 15, 2004 | 02:47 PM
IronbackTA's Avatar
Car: 86 Aero TA
Engine: ZZ4
Transmission: T-56 Rear: Dana 44
If you are running a ZZ4 cam with no head work and just the mods you listed, 24's are more than adequate, plus an AFPR. 30's would be a bit too much. Summit must have a sale or trying to push old stock. You are running a combo pretty close to what I was. From experience you need a set of gears, torque convertor, tranny cooler, and at least a shift kit. 3.73's or 3.42's would wake it up! You would swear it was a different car, trust me, been there.
Old Jul 15, 2004 | 05:44 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
The car is my moms daily driver.
My dad still wants 30 lbs, one reason is the GN came stock with 30 lbs injectors.
Old Jul 15, 2004 | 06:07 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
The GN was also turbocharged..
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
Magman
Sep 13, 2015 12:14 AM
