Injector pulse
Old Jul 15, 2004 | 11:26 PM
KS91Z28's Avatar
Injector pulse
I've been working on my sister's car for a few hours now. It runs like crap even after changing injectors, pick-up coil, ignition module, plugs, wires, cap, rotor, and fuel filter. I finally started pulling injector plugs off one at a time. This seemed to greatly effect the engine on the driver's side, but it didn't have any affect when I did this on the passenger's side. So, I started checking for injector pulse and there doesn't seem to be any on the passenger's side. What could cause this?
On my drive home, I was thinking about it and was wondering if one of the fuses labeled "INJ1" or "INJ2" could cause this. Am I on the right track?
Thanks in advance for any help or suggestions.
Old Jul 15, 2004 | 11:48 PM
KS91Z28's Avatar
Ok, I just had my sister go check the fuses. Sure enough, there was a blown fuse. She says the car is running much better, but still has a rough idle with a little bit of a surge.
Old Jul 16, 2004 | 08:58 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Have her disconnect the ecm, or unplug the battery for a few minutes, then go out for a test drive.
Old Jul 16, 2004 | 09:23 AM
KS91Z28's Avatar
Yeah, that was real helpful advice. If you're just going to be a smart @ss, don't bother responding.
Old Jul 16, 2004 | 10:10 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Listen dickwad, the reason to disconnect the ECM is to clear it's learned state from running on only 4 injectors.
Old Jul 16, 2004 | 11:24 AM
KS91Z28's Avatar
Name calling, now that's real mature. Anyways, if you were sincerely tring to be helpful, I apologize. It would have helped to mention what you were trying to accomplish by unhooking the computer or the battery in the first place. Thanks for the idea.
Old Jul 16, 2004 | 02:13 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Interesting, you call me a smartaxx, then cite my lack of maturity for name calling.
Old Jul 16, 2004 | 09:21 PM
jerflash's Avatar
Car: 90 Formula, 02 ws6
Engine: 305 tpi, ls1
Transmission: 700r4, t-56
Axle/Gears: stock posi 2.73, 12 bolt with 4.11s
i have the same problem and changed all the same parts as you
im going to have to check that injector thing
92-Formula
Dec 12, 2015 10:34 PM
327IROC85
Sep 23, 2015 12:11 AM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
Ranbo108
Sep 9, 2015 12:20 PM
