Scan tool!!!!
Old Jul 21, 2004 | 05:34 PM
Scott57350's Avatar
Car: 1991 Z28
Engine: 355 TPI
Scan tool!!!!
Ok guy i need help. i want to get a scan to to check out my chip that I have been getting burnt. Already on my 3rd chip and Im sick of bugging people with there scanners. where can I get a scanner to read my block learn and stuff. and how much are they. I don;t have a lap top so that outa the ? Just want soemthnig basic that will read the data while im driving? By the way i have a 1991 Z28
Old Jul 21, 2004 | 05:55 PM
mikobu3's Avatar
same here i would like to no myself
Old Jul 21, 2004 | 06:03 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: Scan tool!!!!
Probably an autoxray. Prices vary from 150-300 bucks.
Old Jul 21, 2004 | 06:12 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
You can get a refurbished Auto X-Ray from a place in Phoenix, Arizona for ~120$. Sorry, can't remember the name of the place. I bet Google knows.
Old Jul 21, 2004 | 06:16 PM
Scott57350's Avatar
Car: 1991 Z28
Engine: 355 TPI
would this work. its at summit and is 175
part # AXY-10110 GM: 1982-1995 vehicles with a 12 pin ALDL connector and OBD-1 computers, diagnostic scanner. would this do what i need it to and will it work when im driving to read the stuff?
Old Jul 21, 2004 | 08:44 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Yes. I used to have one before I went the laptop route.
Old Jul 21, 2004 | 08:45 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Access to a laptop, spend $10 to make your own aldl cable or 25$ to buy one and use moates free software. works like a charm :-)
later
Jeremy
Old Jul 21, 2004 | 09:24 PM
Try and remember could you? I want one...
Old Jul 21, 2004 | 09:38 PM
5SIZ's Avatar
Car: 1987 IROC-Z
it's SO much cheaper to go the laptop route, I have a 75mhz butterfly laptop that ran moates software and I got that thing for 40 bucks, another 40 for the pre made aldl cable and with under 100 bucks I was able to read everything I wanted and was that much closer to burning my own proms.
I'm not trying to sound rude, but don't spend 150+ on an auto X-Ray, they're pointless when for less you can be scanning w/ a laptop. just look around and you'll find a deal.
Old Jul 21, 2004 | 11:59 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
I may be overly cautious, but why the hell did you bypass your knock sensor?
Old Jul 22, 2004 | 12:46 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Ok guys, did some research on the Auto X-ray diagnostic scanner. The only thing I cannot find about it, but does it record things? With my friends autotap for obd ii, he can hit record, go down the 1/4 track, hit stop, and look at all his sensors during the wot run. Is it possible to do that with the auto X-ray diagnostic scanner?
Old Jul 22, 2004 | 01:12 AM
Synapsis's Avatar
Car: Sexy
Engine: Stock
It records, VERY slowly and only for like, 10 seconds or so if I remember correctly. If you want to record data, go the laptop route.
Old Jul 22, 2004 | 12:54 PM
Scott57350's Avatar
Car: 1991 Z28
Engine: 355 TPI
ok so I might have a free laptop now. no can someone tell me where I can get the cable or how to make the cable and can someone post me the link to the free software and how hard is it to do all this is it pretty self expl. thanks
Old Jul 22, 2004 | 01:08 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Head on over to the Prom forum. All the info is in stickies at the top.
92projectcamaro
Dec 8, 2015 12:25 AM
1992Z28!
Nov 19, 2015 07:33 AM
Reid Fleming
Oct 10, 2015 09:56 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
RGB2015
Sep 20, 2015 09:26 PM
