tpi valve seals
Old Jul 26, 2004 | 09:04 PM
350f_bird's Avatar
Car: 91 firebird formula 350 or 94 grand am se
Engine: 350 or 3.1
Transmission: 700r4 or what ever a grand am has
tpi valve seals
has anyone ever replaced valve seals on a l98? any problems? any mods that would be good on a stock engine that could be done as part of this project that are CHEAP? just looking for advice
thanks
Old Jul 26, 2004 | 09:19 PM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
Change to 1.6 and or roller rockers.
Old Jul 26, 2004 | 09:39 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
valve seals are not as hard as they seem. Changed the ones in my Caprice a few months ago.
Perform a search for "valve seal replacement" or something along those lines. I know i have posted a quick run through before.
As for the rocker arms that warbird says, depending on budget, the best BUDGET pieces i have seen that AREN'T aluminum are the Comp Magnum roller tips. Otherwise the Pro Magnums are out there. Both are steel, not the aluminum that is very common. Crower also makes steel full roller rockers. I would get 1.6 ratio.
On a side note, how cheap is cheap? You know the saying:
How fast you want to go depends on how much you want to pay
Old Jul 27, 2004 | 06:33 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I used cat roller rockers. Spend a lot of time at 6000rpm. seem to hold up just fine.
-- Joe
Old Jul 27, 2004 | 07:11 AM
eddie89TA's Avatar
Car: 89GTA
Engine: 355TPI Edelbrock heads, base. SLP r
Transmission: TCI streetfighter 700r4
Axle/Gears: B/W3:27
i did it.. use high quality seals, i learned the hard way, and it made me get a lot of practice. and buy a antenna tipe magnet to help get keepers off and on.
Old Aug 8, 2004 | 09:41 PM
IrocZonNos's Avatar
Car: 1988 IROC CONVERTIBLE
Engine: 305 TPI PAXTON SUPERCHARGER & NOS
How long did it take to replace valve stem seals. Any helpful tips woud be appreciated.
Old Aug 8, 2004 | 10:12 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
I can do all 16 in under 2 hours. Key off to key on.
I like the Fel-Pro viton valve seals. They are the positive type and do not require machining to the valve guide boss.
Old Aug 9, 2004 | 02:58 PM
IrocZonNos's Avatar
WOW!!! Did you actually mean 2 days? Just kidding... Anyhow did you R/R the valve seals in 2 hrs with the heads still on the motor. Let me know how to expedite this process.
Thanks!!!
gta90
Sep 15, 2015 04:00 PM
NBrehm
Aug 25, 2015 11:49 PM
Out-Cast
Aug 17, 2015 10:57 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Sanjay
Aug 12, 2015 03:41 PM
