Size of FPR screws?.....
Old Aug 8, 2004 | 10:31 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Anyone know the size of the torx screws that hold the FPR cover inplace? I stripped the head of one today and want to replace it, preferably with some stainless allen head screws if possible.
I hit my local OSH and nothing seemed to match. These seem to be some one-off size.
Old Aug 9, 2004 | 06:23 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
They're either a T10 or T15.
Ed
Old Aug 9, 2004 | 09:11 AM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
I don't think he is referring to the torx bit size to loosen them, but the size of the bolt itself. I have a messed up thread on one of the fuel pressure regulator holes and was looking for a tap to clean the threads yesterday. Closest size I could find was I believe 6-32, but the threads are finer on these bolts than the 6-32. I looked through boltdepot.com, as they have alot of stainless allen bolts, but I couldn't find any other size. Please let me know if you find out anything, I could really use the help as well. I'm only wondering how hard it will be to find a tap in that size when I can't even find the bolt size.
Old Aug 9, 2004 | 09:51 AM
ebmiller88's Avatar
Sorry, missed that...
Ed
Old Aug 9, 2004 | 12:39 PM
Car: Yes...
When I compared the FPR screw to the various sizes OSH carries, it seemed to be in-between. 6/32 looked a hair to small in diameter and 8/32 was too big. Thread pitch is also closer 40. 32 is too course.
In metric, M3 was to small in diameter and the thread pitch was too fine. M5/.08 had too course of a thread pitch. I ordered some M4/.07 pitch screws to see if these are a match. If they work I'll post the results.
Old Aug 9, 2004 | 02:23 PM
gnatshop's Avatar
Car: '94 GMC Sonoma
Engine: 406 sd TPI
FPR Screw - 3.5mm x 12mm .6 thread pitch
Just went thru this myself last week.
The screws are 3.5mm by 12mm, .6 thread pitch.
I found my replacements in a local hobby shop, in the remote control airplane, boat, and car section.
They were 20mm long, but I just cut them to length with a Dremel cut-off wheel. They also had a socket head (allen wrench). Much better than the torx.
They were made by DuBro.
Their home page:
www.dubro.com/DU-BRO/
On-line Catalog page with these screws:
http://www.shopatron.com/index/pg=4/....5167.5209.0.0
Hope this helps,
David
Old Aug 9, 2004 | 03:43 PM
Car: Yes...
Re: FPR Screw - 3.5mm x 12mm .6 thread pitch
Hope this helps,
David
Thanks David! I'll see if I can find some locally.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Linson
Sep 21, 2015 01:08 PM
gta892000
Sep 16, 2015 12:37 AM
m00n420
Sep 11, 2015 02:39 PM
Strick1
Sep 4, 2015 07:11 AM
