Surging problem
Old Jul 31, 2004 | 09:14 AM
steve8586iroc's Avatar
Surging problem
I've got a problem with a stock 91z. It starts and runs good cold, seems to run good when up to temp, but when driving on the road at a steady cruise it has a noticable surge. It's more annoying than anything. It still idles good at normal temp but seems to have a floating idle also. I have checked all the vacuum lines and all seems good, no leaks. The tb and manifold have no leaks either. I have run Seafoam fuel injector cleaner thru it as well as running Seafoam thru the maniflod. It has new plug and the ignition system is in good condition. I'd sure appreciate any ideas as to where to look next.
Old Aug 1, 2004 | 02:21 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Check you TPS for smooth changes in voltage, or in resistance when disconnected. The range most used would tend to wear out faster causing abrupt changes in voltage when maintaining the TPS in that range i.e..throttle position.
Old Aug 1, 2004 | 04:56 AM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
does it surge on level road with the Cruise Control on?
Old Aug 1, 2004 | 05:36 PM
I will check the tps and see if there is a problem. I am also going to check the O2 sensor as well.
Yes, it is most apparent when cruising on level ground. At the moment my cruise control dosn't work.
Thanks for the replys.
Steve
Old Aug 1, 2004 | 10:03 PM
mckenzie's Avatar
hello, fellow vol!! i live just west on I-40 in crossville, tn. well, i'm having the exact same problem. starts and idles great. i have a 91 z28 350tpi with 138k and get a surge when crusing 40-55 mph. steady pressure on throttle. at first, i thought it maybe a/c kicking on and off, but turned it off, and it still does it. i plan on checking tps for open, o2 for running lean, and fuel pressure for being low/high. please keep me updated on any progress you have. i tried to post a pic, but it said file too big. anybody know how to reduce a pic to post? thanks, and best of luck, tom
Old Aug 15, 2004 | 08:50 PM
mckenzie's Avatar
well, after checking the car out, the tps tested good, no opens. o2 was also good, lean/rich during cruise/surge. fuel pressure was appx 41 psi, a little low. i think the spec's are 41-47. i unplugged the egr solenoid, and couldn't get the car to surge, but the ses light came on for a code 32...lol. anyway plugged the solenoid back in, and unplugged the egr valve. hope that may help someother folks. best of luck, tom
Old Aug 15, 2004 | 09:30 PM
Tom, thanks for the update. I also checked the the tps and it was ok. I'll check the egr valve tomorrow and see what happens.
Steve
Old Aug 15, 2004 | 09:34 PM
mckenzie's Avatar
no problem. i just blocked off the vacuum line from the solenoid to the egr valve. i'll keep you updated as i'll drive it appx 60 to work tomorrow (30 each way).
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
