t-56 swap aftermath
Old Aug 1, 2004 | 03:35 PM
914Mula's Avatar
Car: 91' Formula
Engine: 383CID
Transmission: t-56
Axle/Gears: 4.10
t-56 swap aftermath
I swapped in a t-56 in my car which used to have a 700r4. When I pulled the auto out , my car was running great all around. I couldn't have asked for any better. when the t-56 went in. I could barely get the car to move off the line. it runs extremely lean until about 2500- 3000 rpms somtimes backfiring through the intake. could this be from the diferent gearing or what. Full throttle it runs ok but it seems a little slower. any ideas?
Old Aug 1, 2004 | 03:40 PM
HoustonL98's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 5.7TPI
Transmission: TH700R4
Maybe I have no idea what I am talking about. But did you accidentally clip any vacuum hoses, or not plug them in?
Old Aug 1, 2004 | 03:43 PM
914Mula's Avatar
Car: 91' Formula
Engine: 383CID
Transmission: t-56
Axle/Gears: 4.10
good thought, but all my vacuum lines are new and plugged in . that was one of the first things i checked.
Old Aug 1, 2004 | 03:45 PM
87Formula4bbl's Avatar
Car: '87 Formula
No check engine codes?
Old Aug 1, 2004 | 03:47 PM
914Mula's Avatar
Car: 91' Formula
Engine: 383CID
Transmission: t-56
Axle/Gears: 4.10
Nope, not a single one
Old Aug 1, 2004 | 03:48 PM
HoustonL98's Avatar
Engine: L98 5.7TPI
I am not trying to insult your ability AT ALL but are the vacuum lines going to the correct places? Just shootin some idea's out. I cant think of much else that could cause the engine to have a problem during an install like that except for vacuum lines.
Old Aug 1, 2004 | 03:55 PM
914Mula's Avatar
Car: 91' Formula
Engine: 383CID
Transmission: t-56
Axle/Gears: 4.10
Originally posted by HoustonL98
I am not trying to insult your ability AT ALL but are the vacuum lines going to the correct places?.
Yep, yep , fuel regulator , map, brake booster, and cruise control. egr is gone b/c of Stealth Ram. no offense taken
Old Aug 1, 2004 | 05:14 PM
60504's Avatar
Car: 92 Camaro
Engine: ZZ4 350 HSR
Transmission: G-Force T5
So you only replaced the auto with a T56 and the engine runs worse? How is that possible?
I too, am having problems after an auto to manual swap, but my problem is clutch release - it's not happening...
Did you do any other mods that would affect the engine's performance? What clutch did you use?
Old Aug 1, 2004 | 07:23 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Just throwing out another idea....maybe the distributor cap hit the firewall when you pulled the trans out, damaging it somehow or dislodging one of the plug wires.
Old Aug 1, 2004 | 08:39 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
Did you do something about the VSS hookup (i.e. SGI-5 or tailshaft mod?) If you have no VSS signal to the ECM that can cause problems off-idle, especially with an auto trans prom in a manual car. I've never seen it cause actual backfiring though.
Old Aug 1, 2004 | 11:08 PM
mike88form350's Avatar
Car: 88' Formula 350
Engine: 358 ci TPI
Transmission: Tremec T-56
thegreatj is correct. no vss signal to ecm = low rpm drivability probs.
i also agree with iroczz3, alot of people forget to remove the dist cap and crack it on the firewall when you remove the auto crossmember and the engine tilts back, i've seen that first hand.
Old Aug 2, 2004 | 08:56 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
couple things to try:
1. you pulled the distrib.... so you could have the plug wires on the cap wrong.
2. if you didnt pull the distrib, the cap hit the firewall. replace the cap and rotor.
3. make sure the two wires that tell the ECM its in nutural are NOT touching.. ive seen people connect the two before... if you connect them, the ECM thinks its in nutural, and you get drivability probs.
disconnect the two, tape them out of the way and presto, zero driving probs.
so simple... but people just dismiss it as "oh, its because it was a auto. "
4. what rear gears do you have? the t56 has a VERY VERY tall 1st gear. stock gearing was never numericly lower then 3.42.
if you have a 2.73 rear gear, its a bitch to drive around. esp in traffic. i know because when i did the swap, i drove it like that for a month.. it SUCKED. swap to 3.42 or better gears, and you'll wake it up alot.
Old Aug 2, 2004 | 06:40 PM
914Mula's Avatar
Car: 91' Formula
Engine: 383CID
Transmission: t-56
Axle/Gears: 4.10
The vss is hooked up and working properly otherwise it would have thrown an engine code. I'll check the dist cap but I don't think that is it b/c I removed my intake during the t-56 swap for a little port matching. The clutch is a SPEC stage 3. The park nuetral switch interests me the most. I just taped mine together so i could start my car without touching the wires everytime. How do I bypass that junk? use a manual electrical ignition switch?
Also I have 3.23 gears and I agree it is a biyatch to drive around sometimes. just haven't had the money for gears yet
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
cRoe4
Aug 7, 2015 08:46 PM
