do you all agree?
Old Aug 2, 2004 | 05:13 PM
1992rs/ss's Avatar
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
do you all agree?
ok did a search and found conflicting info. I am putting in ls1 injectors but of course they are a shorter injector. do I have to grind down the fuel rail supports on the manifold to make them fit correctly? I installed them and they are pushed in as far as they can go in the manifold. the O-rings in the fuel rail are just slightly visable on the bottom of the fuel rail. without bolts they hold the into the rails if you don't tug on them too hard. here are some of the best pics I could get at it. tell me what you think. I really would like to avoid a leak and a big fire.
Old Aug 2, 2004 | 05:14 PM
1992rs/ss's Avatar
another
Old Aug 2, 2004 | 09:18 PM
1992rs/ss's Avatar
anybody? I know that the stock injectors would be roughly a 1/4 of an inch farther in. anybody?
Old Aug 2, 2004 | 09:38 PM
razor's Avatar
Car: 1992 GTA
Axle/Gears: 4.10
On my LS1 injectors I never ground off the fuel rail supports. I also had my injectors up just a bit higher into my fuel rail so that you can't see the bottom of the o-ring. Never had any problems or missed a beat since doing it last spring. The extra 1/8 inch I have mine tucked up into the rail does not affect the plume from the injector as it fires. No fuel drip just a nice pattern. Maybe just tuck your injectors up a bit to play it safe. Would hate to see you push any fuel past the rail and onto a header,ect.
tyeo098
Nov 30, 2015 06:27 PM
87iroctheo
Wheels and Tires
Sep 2, 2015 03:29 AM
Redwhisper
Aug 26, 2015 05:02 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
snflupigus
Apr 30, 2001 12:54 AM
