No power past half throttle
Old Aug 11, 2004 | 06:02 PM
88fbird's Avatar
Car: 84 S-10:(
The car idles okay, and drives fine. Until you mash the gas past halfway. Then it just stops. The nose dives down and everything gets quiet. Then it sputters up and starts to go again. Only with little power. Nothing like normal. This started yesterday on my way home from work. Today I changed my oil and filter, not because of the problem though , checked my plugs and dist cap. I changed the wires last night. Still has the same problems. I don't know where to even start this time. Thanks for any help.
FBird
Old Aug 11, 2004 | 06:30 PM
2.73's Suck's Avatar
Car: 1985 Mustang GT
Engine: hamsters
Transmission: a hamster wheel
It sounds like the fuel filter or pump on its way out.
Old Aug 11, 2004 | 08:07 PM
88fbird's Avatar
Car: 84 S-10:(
The pump is fairly new, but I haven't done anything with the filter yet. Maybe that will be tomorrow's project. Thanks for the lead.
FBird
Old Aug 12, 2004 | 06:59 PM
88fbird's Avatar
Car: 84 S-10:(
I just changed the filter. It still has the same problem. It runs and idles good, until you mash the gas past halfway. I don't know what to change next!
Old Aug 12, 2004 | 07:53 PM
87350IROC's Avatar
Car: 87' IROC
have you checked for codes?
Old Aug 12, 2004 | 08:16 PM
Z69's Avatar
Z69
Monitor your FP.
Old Aug 12, 2004 | 08:31 PM
88fbird's Avatar
Car: 84 S-10:(
I haven't seen a ses light yet. I don't have a fuel pressure gauge yet either.
Old Aug 15, 2004 | 04:35 PM
88fbird's Avatar
Car: 84 S-10:(
Are there any other ideas?
Old Aug 15, 2004 | 05:03 PM
88TAJeff's Avatar
Car: 88 T/A
Have you checked your spark plug wires? a miss in a cyl. could cause what you describe..
Old Aug 15, 2004 | 08:55 PM
87350IROC's Avatar
Car: 87' IROC
That doesn't mean you don't have any codes.
Old Aug 15, 2004 | 09:52 PM
88fbird's Avatar
Car: 84 S-10:(
I already changed the wires, I'll check the codes tomorrow. Thanks
Old Aug 16, 2004 | 10:00 AM
88fbird's Avatar
Car: 84 S-10:(
I checked the codes stored in the computer. I got a code 21. TPS not adjusted or faulty. I adjusted it to specs. It does everything it is supposed to do, goes past 4 volts at WOT and goes up and down gradually. I still have the same problem though. I don't know. Any other ideas?
Old Aug 17, 2004 | 04:10 PM
88fbird's Avatar
Car: 84 S-10:(
TTT?
Old Aug 17, 2004 | 04:20 PM
87350IROC's Avatar
Car: 87' IROC
How does the engine sound? At idle, reving, and driving. Any odd noises? Also do you have access to a scanner?
Old Aug 17, 2004 | 04:36 PM
88fbird's Avatar
Car: 84 S-10:(
I don't have access to a scanner. Everything sounds like normal. It idles, and runs okay. It will rev past 3000RPM too. But if you get on it hard, It doesn't even have to be real hard, it is like you hit a wall. Sometimes if you are going, and floor it, it bogs down, then starts to pick up again. Nothing like normal though. I was thinking it was something in the computer. I just don't know. Thanks for the help though.
Old Aug 17, 2004 | 08:22 PM
87350IROC's Avatar
Car: 87' IROC
how is it if you gun it from a stop, how does the low end torque feel?
Old Aug 17, 2004 | 08:36 PM
88fbird's Avatar
Car: 84 S-10:(
Well, it launches real hard for about a second then the nose dives and there is just silence from the engine for about a second then it surges up so fast it spins the wheels. It just surges up and down like that. It is like I jump on it and then get off of it and back on it. Like someone who has never driven a stick might take off.
Old Aug 18, 2004 | 03:11 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
My problem sounds like the opposite of this one, I can hardly get my car off the line it feels dead upto about 3000rpm then it seems to work ok. I'm thinking it's maybe filling one of the cylinders with too much fuel?
Old Aug 18, 2004 | 04:34 PM
88fbird's Avatar
Car: 84 S-10:(
I was almost out of gas today, so I filled up on my way home. I put in the premium this time. 14.74 gallons of it. Then added some fuel injector cleaner. It is running worse now than ever. It wouldn't even start at the fuel pump. I finally got it to run, but if you mash the gas, it dies. I mean, I had to drive home the rest of the way practically resting my foot on the throttle. Any more and it starts sputtering and dies. I don't know
Old Aug 18, 2004 | 04:41 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
Check all Grounds. I had a similar problem Until I ran a Braid Ground Strap From the Firewall To the back of the passanger head.
Get a Ohm Meter and check Injectors.
Test Ignition Module
Test Coil
How does the rotor button in the distrubutor cap look.
Clean and adjust and test IAC
Just my .02
Old Aug 18, 2004 | 04:56 PM
88fbird's Avatar
Car: 84 S-10:(
I remember putting the braided ground on the head when I installed the engine. I just replaced the ignition module receintly. The rotor in the dist cap looks good and so does the cap. I'm going to get another coil and some new plugs. I'll check the IAC, TPS, and timing again. And I'll look for some grounds.
By the way, my gas gauge was on the fritz for a couple weeks. Always reading full. Well, It seems to be working now. I don't know if there is a connection, but I thought I would mention it. I'm grasping at straws now!
FBird
Old Aug 18, 2004 | 06:15 PM
88fbird's Avatar
Car: 84 S-10:(
Well, the plugs and the coil are new now too. Still no help though.
Old Aug 18, 2004 | 06:50 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
have you checked injectors
Old Aug 18, 2004 | 07:24 PM
88fbird's Avatar
Car: 84 S-10:(
I just checked them with a meter. I don't think I did it right though. I touched both blades off the injector with the meter leads. I was getting around 17.4 on all of them. I looked for bad grounds or wires cut/not connected, and didn't find anything out of the ordinary.
Old Aug 20, 2004 | 04:31 PM
88fbird's Avatar
Car: 84 S-10:(
After driving it around more, it doesn't seem to be as bad in the mornings when it is cool. But if it is hot outside, man it is bad. The only thing I can think is that it is some kind of vapor lock. The #7 header tube is close to the fuel lines. The fuel lines were too hot to touch when I got home today. I haven't done anything to that area since I put in the motor. Does anyone know how I can test this? When I start it while it is hot, I am smelling gas, so I don't even know if I'm heading in the right direction.
Thanks again
FBird
Old Aug 25, 2004 | 04:17 PM
88fbird's Avatar
Car: 84 S-10:(
I just replaced the tps. That didn't do anything. While I was driving, I just floored it and held it down. It starts to accellerate, then just stops. Everything stops. Kinda like I lost all electrical power. it just gets real quit. It doesn't matter what RPM I'm at. Just when the pedal goes more than half. I'm running out of options. I'm planning on getting new injectors and chip burning stuff, but I still have to drive it. Even if it isn't perfect. I just need it running.
Thanks for any sujestions.
FBird
Old Aug 25, 2004 | 04:41 PM
NYIROC's Avatar
Car: 87IROC
Transmission: MAD DOG 700R4 w/3:73 posirear
I've been having the same symtoms with my car. It takes a nose dive when you mash the throttle then picks up.
I unpugged the MAF and no nose dive just crazy lowend burn out power. I'm going to check all the sensors and maybe replace the MAF.
Regards,
G
Old Aug 25, 2004 | 05:55 PM
88fbird's Avatar
Car: 84 S-10:(
I just went out and unplugged my MAF and went for a ride. Man that thing hauls butt now. Thanks for the help. I guess I need to replace my MAF too. At least it is running like normal. Actually it is running better now. Thanks again,
FBird.
Now, does anyone know where to get a good MAF?
Old Aug 25, 2004 | 09:59 PM
86IROCTHD's Avatar
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
hey u know what i am having this same problem... but my ses light flashes and the car just bucks like its all jacked up and has a cold and is sneezing and what not... ok bad analogy lol but its doing the same thing like there is an idiot behind a stick that doesnt know how to drive a stick ... will try the maf tomarrow thanks guys....
Old Aug 27, 2004 | 11:02 AM
NYIROC's Avatar
Car: 87IROC
Did the new maf do the trick?
I've got to replace my rear right now as I blew with at extra low end I've found after ubplugging the maf so its on the back burner right now.
Regards,
G
Old Aug 27, 2004 | 06:46 PM
88fbird's Avatar
Car: 84 S-10:(
I haven't actually replaced mine yet. It is coming though. I might have to wait a week or two. This one came at a bad time. You know how that is though.
FBird
Old Aug 28, 2004 | 02:13 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Throttle Position Sensor. Check for smooth voltage increase, if you open the throttle slowly and the voltage jumps, or fades in and out the sensor is bad, or connections.
Old Aug 28, 2004 | 03:49 PM
88fbird's Avatar
Car: 84 S-10:(
TPS= Throttle Position Sensor.
I'm pretty sure it is the MAF. We sill see when I get a new one.
Thanks anyway,
FBird
Old Aug 31, 2004 | 10:16 PM
formulaman's Avatar
Too bad MAFs are so expensive. I feel for you bud.
Ghettobird52
Jul 5, 2024 11:18 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
novaderrik
Aug 10, 2015 12:44 PM
