Car dies after long trips...
Old Aug 18, 2004 | 01:54 PM
PhantomTPI's Avatar
Car: 1986 Pontiac Trans Am
Engine: 5.0 TPI
.....what causes this? Say i drive from PA to NJ....takes about 2 to 2 1/2 hrs to get from where i'm at to my destination. Most of the way, the car is traveling with sustianed speeds of 70mph.....when i get into town, and come to a stop light, the trans downshifts, (i can hear/feel it) and i come to a stop. Then the idle falls exteremley low, and the car wants to stall out or actually does stall out. WTF?? After i park it and it cools down for a couple hours, if i go to use it again, its fine. What could be the cause of this? There are no codes showing up.
Old Aug 18, 2004 | 10:08 PM
PhantomTPI's Avatar
Engine: 5.0 TPI
TTT
Old Aug 19, 2004 | 01:53 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Ignition coil. How old is yours? Mine used to do that, even checked out good on the old resistance check, but was still bad.
Old Aug 19, 2004 | 03:23 PM
PhantomTPI's Avatar
Engine: 5.0 TPI
Brand new ignition coil....all iginition pieces are pretty much new, so are the wires, plugs, etc...
Old Aug 19, 2004 | 03:45 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Try setting the TPS.,cleaning the TB and resetting and cleaning the IAC
later
JEremy
Old Aug 19, 2004 | 04:36 PM
PhantomTPI's Avatar
Engine: 5.0 TPI
later
JEremy
The IAC and TPS were recenetly replaced with new parts, however, i cannot be certain aobut how good the quality of the new parts are. I'll have to try to replace both again i guess, and clean the TB. Thanks.
Old Aug 23, 2004 | 03:35 PM
Steve89GTA's Avatar
I've always attributed this type of engine behaviour to the fact that running for long periods of time always tends to heat soak all ignition/electrical related stuff under the hood...leading to false readings and a ****ty running motor.
Some also say it's because of the dirt, grime and sludge that gets loosened up after running for a prolonged amount of time...i dunnno..
Old Aug 23, 2004 | 04:15 PM
PhantomTPI's Avatar
Engine: 5.0 TPI
I think its BS if you cant drive a sports car for 2+ hrs and not be ablet to expect it to have no problems. Whats the point on having one then?
Frozer!!!
Jan 19, 2024 04:55 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
