best way to replace the spark plugs
Old Aug 20, 2004 | 02:56 AM
waldothejuggalo's Avatar
Car: 89 gta
Engine: 5.7 tpi
Transmission: automatic
i need to know the best way to replace the spark plugs in my car i have an 89 g t a with the 5.7.i can get to the one on the drivers side good but need to know if there is an e z way to get the ones on the right side out
Old Aug 20, 2004 | 03:49 AM
Morley's Avatar
The front 2 on the passenger side you can get from the top, the other 2 you'll have to jack the car and get them from underneath.
Old Aug 20, 2004 | 11:05 PM
Car: 89 gta
Engine: 5.7 tpi
thanks for the info
hay thanks for the info it makes it ezer.
Old Aug 20, 2004 | 11:09 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
jack up the car at frame put on jack stands take front wheels off go throw wheel well.
Old Aug 20, 2004 | 11:48 PM
ljnowell's Avatar
How the hell does that work on a thirdgen?????
Old Aug 20, 2004 | 11:52 PM
Ragtop89's Avatar
Re: best way to replace the spark plugs
Originally posted by waldothejuggalo
best way to replace the spark plugs . . .
I do them one at a time . . .
Headers + no emissions = 20 minute job
:lala:
Old Aug 31, 2004 | 10:49 PM
formulaman's Avatar
Underneath is the only way to get them without going crazy..
Old Sep 1, 2004 | 08:57 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Yep, I just drive it up on a set of ramps and slid under neath.
Actually, the only plugs I still change from above are #1,3, and 5.
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Feb 28, 2016 03:33 PM
db057
Aug 22, 2015 08:17 PM
Bryan F
Aug 18, 2015 02:28 PM
