Black Smoke then white when car starts up HELP
Old Aug 21, 2004 | 01:34 PM
camarochic's Avatar
Car: 86 Camaro Iroc-z, 86 Corvette
Engine: 350 TPI Camaro, 350 tpi Corvette
I have an 86 camaro Every Time I start the car up Black smoke comes out of the tail pipe and then some white smoke. How Do I stop this and what could be the problem Please Help Thanks :lala:
Old Aug 22, 2004 | 03:22 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Seems too rich at startup, you need to hook a scantool into it, and watch the startup parameters, CTS,...might be a simple sensor problem, or coldstart injector, MAF values, bad injector(s), etc....that's why a quick look at at what the ECM see's at startup, can point you in the correct direction.
Old Aug 22, 2004 | 03:33 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Black-running rich
Blue tint-burning oil
white-burning water/coolant
Are you absolutly positive its white after the puff of black and not really a light tint of blue? What does it smell like (if you can get a smell over the puff of too much fuel)?
Old Aug 22, 2004 | 03:47 PM
Russ-So Cal's Avatar
I've been a transport refrigeration mechanic for over 30 years working on small diesel engines, and I've never seen the difference between "white smoke" and "bluish smoke", I would bet he is seeing a puff of "blue" smoke and probably has some valve guide seals leaking. Undoubtedly, he has a fuel rich problem on cold start. By the way, does it put out black smoke on start up every time, or just when cold?
Old Aug 31, 2004 | 10:40 PM
formulaman's Avatar
I vote for the valve seals.
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Wade787b
Sep 29, 2015 01:15 PM
squiggy2
Aug 9, 2015 09:30 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
