More Horsepower?
Old Aug 23, 2004 | 11:07 PM
92Camaro305's Avatar
Car: Camaro
Engine: 305TPI
More Horsepower?
I was wondering what is the best way to get more horsepower from an 87 305 tpi motor. I have already had head work done, headers, port and polished. What else can be done?
Old Aug 24, 2004 | 03:05 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Cam it and tune it. A new intake setup might be benificial as well.
Old Aug 24, 2004 | 08:36 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
Agreed. Intake, cam, and tune.
You could go all new intake or port and get runners for the current TPI. Would be very beneficial to match to your current heads.
Old Aug 24, 2004 | 08:48 AM
Car: Camaro
Engine: 305TPI
Thanks for all the help
Sorry i forgot to list i already but i already put in a high performacn roller cam. What would you recommend for intakes?
Old Aug 24, 2004 | 11:01 AM
Steve89GTA's Avatar
PROCHARGER
Old Aug 24, 2004 | 02:22 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
read my sig for more ideas and average results with zero tuning as of yet.
Old Aug 24, 2004 | 04:45 PM
My opinion, and hopefully some more will chime in...
The cam is not large and the gears are not too big, so I would stick with larger runners, larger base, and ported plenum. If that is not enough in the end add a power adder for more power and a little more help in the higher RPM range.
Either that or do the superram for a little more rpm range, but I don't think it would cost effective for you considering it likes single pattern cams.
Old Aug 24, 2004 | 06:10 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Modified LT1 intake. Should work pretty well with the cam you have now.
PurelyPMD
May 5, 2016 04:57 PM
dbrochard
Sep 25, 2015 04:56 PM
scottmoyer
Sep 5, 2015 09:33 AM
formula_novice
Sep 5, 2015 03:58 AM
1LE91
Aug 31, 2015 08:13 PM
