Oil in intake??PCV or two seperate valve cover breather vents
Old Aug 29, 2004 | 07:17 PM
robsgta's Avatar
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
I am getting oil into my motor from the crank case vent line on the passengers side valve cover.
Has or does any one in here use two seperate valve cover vents instead of using the stock pcv set up??
will doing so change any of the motors driving or idling characteristics??
rob
Old Aug 29, 2004 | 09:42 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I run a clear fuel filter on my PCV line. Replacement filters are cheap enough. I just got it from the Spectre isle. ANother choice is a catch can design.
Changing the setup to something cooky really won't help. In the end, you still need a line, running through a check valve, that leads from a valve cover to the intake. As long as you have that, and it isn't protected by a baffle or some other means, you will get gunk in your intake.
MoJoe
Sep 24, 2015 09:12 PM
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
1985chevydude
Aug 20, 2015 12:29 AM
mustangman65_79
Aug 8, 2015 01:18 AM
