fastburn???
Old Sep 9, 2004 | 02:40 AM
Kandied91z's Avatar
fastburn???
is there a base that can be used to make a super ram work on these heads?
Old Sep 9, 2004 | 08:54 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
don't the fastburn heads have the same bolt and port configuration as the Vortecs? If so, SPDC's vortec intake should work.
Old Sep 9, 2004 | 09:29 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I think they are similar except the fastburns have raised runner ports. I not sure but thats what I thought. Sorta like the Lt1 to Lt4.
Old Sep 9, 2004 | 09:30 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Or get some Dart/World Products Sportsman II heads. They're the same fastburn type compression chamber as well, and fit/use all the standard TPI and small block intakes. I'm using the Accel/Lingenfelter intake with my SuperRam 383 setup.
Old Sep 9, 2004 | 02:19 PM
Kandied91z's Avatar
ok guys...i have fastburn heads. i want to know if there is a base i can use that will let me adapt a superram?
Old Sep 9, 2004 | 03:17 PM
vernw's Avatar
I believe you'll have to use the Scoggins-Dickey Vortec-TPI manifold to use them. Call them and ask them.
1-800-456-0211 or 1-806-798-4108
They'll gladly tell you if that manifold is required, or if any standard SBC manifold (like the SuperRam Accell/Lingenfelter, Edelbrock, TPIS big mouth, etc.) will work.....
Old Sep 9, 2004 | 07:46 PM
jms's Avatar
jms
The Scoggin-Dickey Vortec TPI intake will work but be prepared to do a great deal of porting on the intake to get it close to the size of the FastBurn intake runners (especially around the injector bosses).
In addition, the port size on the plenum side of the intake should also be opened up and there is plenty of material there to do so.
The transition areas between the head side and plenum side in the runners needs to be carefully blended to keep the flow up and balanced between the cylinders.
Just my experiences.
jms
Old Sep 9, 2004 | 09:00 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
You can use the SDPC intake for the Vortec heads on the Fastburn heads and then us the Superram on the SDPC intake. I am using the E-tec 200 head instead of the fastburn heads with the Superram and it works great. There are some minor interferance issues with the Superram and SDPC intake but with a little creative thinking the issue can be resolved.
Old Sep 10, 2004 | 01:02 AM
Kandied91z's Avatar
thanks everyone....just trying to gain back some torque i lost using the miniram.
Old Sep 10, 2004 | 03:04 AM
OMINOUS_87's Avatar
Re: fastburn???
What you can do is get your hands on a set of Felpro 1255 intake gaskets.
If the ports on the heads match up with the 1255 gasket you are in good luck.
The SDPC Base can be ported to match the 1255 nicely, but not a whole bunch further beyond it.
Did you sell the miniram?
I got a ported Superram with SDPC base I might be willing to trade you or sell, oh yeah it is already ported out like a ****.
Old Sep 10, 2004 | 03:34 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
I have the SDPC High Flow Vortec base on my 88' TPI 388cid with Alum fastburn heads.
Old Sep 10, 2004 | 03:38 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Re: Re: fastburn???
I'm I mistaken or is the radiator hose in this image collasped? Why?
Old Sep 10, 2004 | 09:14 AM
Kandied91z's Avatar
lol..yeah, do tell?
email me and let me know what your asking...i've been looking at quite a few setups. i plan to pick one up monday. i sold the miniram though as i had it up for sale here for almost 3 weeks now.
rgarcia63, please do tell more....i want to know how much work it will be to get the thing to fit properly.
Old Sep 10, 2004 | 11:50 AM
OMINOUS_87's Avatar
All you ever needed to know.
https://www.thirdgen.org/techbb2/sho...highlight=sdpc
Old Sep 10, 2004 | 10:56 PM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
Vortechs = raised ports
Fastburns = raised ports but typically come a bit larger. Vortech base can be ported to fit.
LT4 also = raised ports and I'm surprised nobody has done a Vortech head LT4 conversion yet... I'm thinking a 305 6" rod with Vortech heads and an LT4 for awsome mileage... somebody stop me...
Old Sep 16, 2004 | 07:49 PM
Kandied91z's Avatar
so did you sell the super ram setup? if not let me know...still looking and trying to figure out what to do.
RedLeader289
May 28, 2019 01:47 PM
RedLeader289
Sep 23, 2015 06:50 AM
LottaBallsCamaro
Feb 19, 2002 08:31 PM
Bort62
Aug 20, 2001 04:26 PM
super chevy
Dec 8, 2000 12:35 PM
