400+HP HSR owners chime in!!!
Old 09-10-2004, 11:19 AM
mess21's Avatar
ok heres the deal i'm planing a engine swap and was goin to do the LS1 swap but for some reasons i decided against it. So who out there is running a holley stealth ram setup on a 350 engine and has 400+ N/A RWHP??? if you would please share the rest of ur setup with me ie cam heads etc. or does anyone have a idea of what it will take to make this kind of power with a HSR setup. oh by the way i plan on using a ZZ4 short block as the starting point. thanx
Old 09-10-2004, 02:34 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Dont think the ZZ4 shortblock will hold 400rwhp. Thats like 500 on the crank. Think the rods only rated at 450. I wouldnt push that. Think on a 350 tho, your gonna need some serious stuff. do a 383 for that power.
My guess 195-210 cc heads that flow good like AFR or others. ZZ409 cam or bigger, HSR and one hellofa tune. Should be close. you will be looking for high rpms
Old 09-10-2004, 10:15 PM
camaro05's Avatar
Car: 91 Z28
Transmission: built 700R4
I would like to get this motor and put HSR on it instead of a carb. Auper AFR ZZ4
Old 09-13-2004, 12:23 AM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
I should have 400hp at the crank, but not at the wheels. Setup in sig link.
Old 09-14-2004, 11:45 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Do you have ANY idea about what that might be putting down? Track times? Engine dyno sheet? Are you just assuming you have 400 at the crank? Also, what are the specs on your cam?
You don't need a 383 to make 400rwhp. And 450-500 hp won't break a PM rod. UNLESS that power is made at 8,000rpm.
You won't have to spin the HSR quite that high, but RPM kills a motor much faster than power output.
Put a 150 shot on a 305 and shift at 5k. Then take an all motor (built top end) 305 and shift at 7500 (if it'll make it).
Point is, you should be able to see your goal at less than 7000rpm. But it's not easy. I've chose to use the protopline200cc heads, a cc306, to match w/ the HSR. If I get close to 400, I'll be estatic.
Old 09-14-2004, 12:21 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
good to know, GM rates those PM rods at 450hp so I thought it wouldnt be good to do some serious work to a motor with those rods. I want to get the ZZ4 shortblock and add heads/superram.
Will those rods hold 400 crank hp at 5800rpm?
Old 09-14-2004, 02:55 PM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
I used to spin mine to 6500 and spray 100 shot on it. They did pretty well. the 450 mark is to cover their AS$e$
Old 09-15-2004, 11:37 PM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
No, just assuming. Maybe I should keep my big mouth shut, eh?
Cam is a Comp XR282HR. 230*/236* @ 0.050", .544"/.555" w/ 1.6:1s, 110* LSA
Old 09-15-2004, 11:50 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Many articles claim that with a good buil up with heads and the rest with a HSR 400 hp at the crank is perfectly attainable. Provided a good tune on the 355. Most people can put down a 12 second 1/4 mile. My combo is in the sig if it appears.
Did not appear so:
engine:flat top hypereutectic antifriction/heat coated 9.8:1 CR. bored .030 over. deck milled .010 All ARP bolts and studs Moly rings. Double roller timing chain, LT4 "Hot" cam .525 lift and 518 528 duration at .050, Comp cams pushrods, 1.6 roller rockers, Trick Flow Specialties Kenny Dutteweiler aluminum heads, Total emissions delete
tranny:Heavy duty T-5 with a spare T-5.
exhaust:Hooker Super Competition Long tube Ceramic coated headers. TRUE dual exhaust. Cheap glass pack muflers
Ignition: MSD everything with 6A box.
Air/fuel: Holley (Walbro) 49 lbs lbs per hour fuel pump, stainless steel braided 6-AN line Accel 30 lbs/hr injectors. Holley AFPR. Stealth ram with AFPR
ECM: Mega Squirt stand alone fuel managment
rear end: Borg Warner nine bolt with 3.45 and discs
suspension: Energy suspension.
Old 09-16-2004, 10:45 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
look over at www.stealthram.com in the hsr cars section. there is one guy doing 600 rwhp. with a blower though.
Old 10-04-2004, 10:00 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
ive fell in love with stealthrams too, mine should be done shortly and dd2000 rates it at 460hp and 490tq N/A (flywheel)
trickflow 23 heads
something similar to the 282hr
forged 383 10.6:1
but then theres the 150 shot
Old 10-05-2004, 02:23 AM
1320 Right Ln.'s Avatar
trickflow 23 heads
forged 383 10.6:1
dude, i read that first line n' i was like...DAMN!... then i read on n' saw the heads and cam you chose... once again i couldn't believe it........ then i read about the 150 shot n' laughed about the fact that for that one second i actually thought someone made that kinda power on nuts. cheater haha
Oh, BTW i'm making about 380 HP with my stealth ram, trickflow heads, and crane cam. according to DDD that is
Old 10-05-2004, 08:53 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
well the 460 and 490 numbers are N/A numbers without the n2o, its not the exact cam but extremly close, and well see how accurate dd2000 really is come spring when i can get a very good tune done. ive heard dd2000 can be off by as much as 50hp, and while i dont think its quite that much im guessing is probably overestimates a slight amount o well at least theres always juice to put me over 500
Old 10-06-2004, 09:58 PM
TPIMarow6.6's Avatar
Car: 85 Camaro Z-28
Engine: 6.6
Transmission: 5-speed
im not sure but i might be putting close to 400hp at flywheel, not sure tho.....
406 Edelbrock Heads, Crane Roller Retro cam Setup 509/528(542/563) 222/230 slp 1 3/4 headers,edelbrock catback,
9.6:1 Swaped carb-TPI, HSR,BBK 58mm TB, LT1 injectors. T-5 3.27 9 bolt.....
Best Time: 12.68(105.83mph)
Best MPH: (12.78)109.69
Lbibb
05-05-2016 12:00 AM
Briandrex
10-05-2015 06:20 AM
meeklay812
10-01-2015 03:46 PM
mcfastestZ28
10-01-2015 11:23 AM
Aaronv808
Members Firebirds
09-30-2015 12:55 PM
Quick Reply: 400+HP HSR owners chime in!!!
