can the tpi throttle body be pulled apart?
Old Sep 15, 2004 | 04:40 AM
big black bird's Avatar
Car: 1989 transam
Engine: 350 hsr trickflow twisted wedge g2 comp cam 490 lift haltech e6gm ,33lbs bosch injectors
Transmission: t700
i want to powdercoat my throttlebody but to do this i will have to pull it apart i know the coolant cavity and throotle body cover and butterflys can be pulled apart what about the spring and shaft? anyone ever done that
Old Sep 16, 2004 | 04:22 AM
Car: 1989 transam
Transmission: t700
no one has been daring enough to give it a go?
Old Sep 16, 2004 | 07:40 AM
bobsroc's Avatar
Car: 1987 IROCZ
My buddy hogged out his stock TB to 52mm on his 85 350 TPI Vette. When doing this he gutted it first, so yes it can come apart, but since your asking if it can be done, you might concider not doing it and just tape it off. If you thrash it, plan on spending several hundred dollars to replace it.
Old Sep 16, 2004 | 09:34 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
To get it apart, you've got to grind the center of the tab that moves the TPS. Once that is ground off, you can remove the butterflies and slide the shaft out of the throttle body. To re-assemble, you'll need to drill & tap the end of that shaft so that you can thread a screw and a washer into it. The screw & washer will hold the tab that the TPS uses back into place.
This is how TPIS does theirs.
Old Sep 17, 2004 | 02:58 AM
Car: 1989 transam
Transmission: t700
thanks jim you couldnt have given me a better answer to my question
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
lakeffect2
Aug 23, 2015 08:44 AM
justin57
Aug 20, 2015 07:05 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
