Will not run with bypass connected
Old Sep 23, 2004 | 01:09 AM
DRENNON's Avatar
350 with accel gen 6,knock sensor disconnected.
Was running good until non-computer was replacedwith a large lcomputer controled distributor.
Set timming to 6 degrees with bypass disconnced.
While engine is runing connect bypass wire and engine cuts off,injectors still fireing until bypass is disconnected or switch is turned off.Tried advancing and retarding distributor,no help
Wred this way.
Three wire plug from distributor
Black to ground
Brown to white on MSD 6A
Pink to switched +
Four wire from distributor to accel harness
A yellow-est to p2 b1
B blue-rp to p2a2
C whie-bypass to p2b2
D pink-ground to p2 a12
Thanks For any help.
Don
camaro11j
Sep 19, 2018 08:49 AM
TheExaminer
Aug 26, 2015 04:59 PM
beachrodder
Aug 25, 2015 08:05 AM
Bull86
Aug 10, 2015 05:43 PM
