next mod?
Old Sep 26, 2004 | 11:33 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
next mod?
ok once i have my headers installed, what should my next mod be that will give me the greatest improvement in the quartermile?
so far i have ceramic headers, AFPR, gutted air box with k&n filters. new synthetic oil, tranny oil/filter. and a b&m shift kit.
i was thinking either superram or a 2400-3000 stall.
Old Sep 27, 2004 | 12:43 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Supercharge it and add a nitrous kit.
Err...perhaps I should say "what's the budget?" and "try a search."
Old Sep 27, 2004 | 01:11 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
my budget is anything short of a power adder, i wanna work on the engine NA first.
if the intake is my next biggest bottleneck, then ill upgrade to superram, if its the stall, ill get the 2400stall torque converter.. etc..
a search wont help me
Old Sep 27, 2004 | 01:22 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Gears and convertor. Roller rockers wont help much, unless they are 1.6's. Cam would be easy also. All are fairly chaep ane rewarding when done.
Old Sep 27, 2004 | 03:21 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
If its an '89 IROC, shouldn't he already have roller rockers stock?
I say get a cat-back and a high-flow cat. That's a big bottleneck eliminated. Then move onto the intake. Gears and a nice stall between the range you set would work very well also.
Old Sep 27, 2004 | 03:59 PM
SloNlo350's Avatar
Car: 2005 GTO
Engine: LS2
A converter alone got my friend Bo 6 tenths alone on his 93 LT1 and with E.T. Streets he got another 2 tenths (as compared to nitto DR's i believe). He has a 3500 stall with a 2.7 STR though. A bit much for the street, but a converter would do you real good.
Old Sep 27, 2004 | 04:47 PM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
No, but it should have roller LIFTERS.
I go for the Vigilante torque converter, or one of the less expensive converters if you don't mind taking a chance on ruining the transmission. Whatever, buy a good quality converter unless you know someone who build transmissions cheap.
Then some drag radials. Next you'll probably need to upgrade the rearend because the 7.5 gears will go. It never really ends.
Have fun, fix what breaks with better parts, then fix 'em again when those break.
Oh, keep a spare car.
Old Sep 27, 2004 | 06:42 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
thanks
i was thinking torque converter, and yes if i get rocker arms, i wouldnt get any less then aluminum 1.6's
i want to stay away from drag radials for now. with these 2.77's i dont need them.
and finding any gears for a aussie 9 bolt will be hard, but from what it looks, a converter is my next big step.
DuronClocker, i dont need cat-back, i got cutout valve
Old Sep 27, 2004 | 10:16 PM
Car: 1997 Corvette
Wow interesting my mistake. Now I feel stupid... lol. I'm also the same one that figured LT1 heads would be easy to install, and now that they're here, the coolant connections to the rad seem impossible.
Good call on the cut-out as well
Old Sep 28, 2004 | 11:53 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Originally posted by TraviZ
thanks
Gears for a nine bolt are not hard to find. Getting you a different carrier for your nine bolt will be hard. I have gears I could sell you, but not a carrier.
starliner
Feb 9, 2016 08:18 PM
Quzyle
Oct 15, 2015 03:35 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
