valve cover remove need help
Old Sep 29, 2004 | 09:24 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
need to know what i need to remove. to get to the valve cover. please help
Old Sep 30, 2004 | 12:49 AM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
Depends what side it is on. I have an 85 TPI. For the driver's side, I just removed the PCV valve from the cover, and the AIR tubes that run but it..not the ones in the manifold, the ones above it. Then, removed the four nuts holding the cover down, and pryed it off.
Passenger side was a little different. I had to remove heater hose lines, passenger PCV lines, and the AIR tubes to get to it. Then, to get it back on, I had to bend AIR tubes that ran to the cat, remove the alternator, slide it in..man that side was a little tough.
Of course, if you have centerbolt valve covers, I guess everything would be the same except when you go to remove it, you have 4 bolts on top of the valve cover in the center holding it down. Remove those then pull off the cover.
Hope I helped
Kev
Old Oct 1, 2004 | 09:31 AM
jayk2k3's Avatar
Car: 85 camaro z28
thanks for the help.
Old Oct 1, 2004 | 09:41 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
you have a 91.
everything moves out of the way... its a bit of a pain to wiggle it out from under the coolent lines and such, but nothing else to undo..
Old Oct 3, 2004 | 09:32 PM
jayk2k3's Avatar
Car: 85 camaro z28
i heard on the fel-pro gasket u shouldn't use rtv sealer is this tru or false thanks.
Old Oct 3, 2004 | 10:35 PM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
IIRC, the installation for the Fel-Pros state not to use sealant.
On mine for the driver's side:
I moved:
the alternator
fuel rails (SLIGHTLY, removing the bolt allows you to move them very little, but they only hang over the lip of the cover by a fraction of an inch anyway)
Remove:
PCV
the clamp that holds the wire harness to the intake manifold.
Doing these, I didn't have to wiggle the cover out. Just removed the cover bolts and lifted it off.
For pass side, its the same basically as what IROC described, minus the AIR tubes. They don't interefere on a TPI at least.
MoJoe
Sep 24, 2015 09:12 PM
NBrehm
Aug 25, 2015 11:49 PM
g.l.mos
Aug 22, 2015 12:02 AM
1985chevydude
Aug 20, 2015 12:29 AM
mustangman65_79
Aug 8, 2015 01:18 AM
