question about stock block
Old Oct 12, 2004 | 01:51 PM
KamikazeIroccy's Avatar
Car: '87 Iroc-Z
Engine: 355cid Cam'd
Transmission: T5 Manual
Axle/Gears: Stock 9 Bolt
How much horsepower can the stock 350 TPI engine block support? I am looking to compete in SCCA racing and was just wondering cause I saw that SDPC offers a crate motor 350 TPI that puts out 375hp and 410lbs./ft of torque
Old Oct 13, 2004 | 05:02 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Are you speaking of the block specifically, or the components within?
Old Oct 13, 2004 | 08:28 PM
92GTA's Avatar
Splay the main caps and have it checked professionally and it should be good to atleast 800HP IMO with a balanced & forged bottom end....
Old Oct 14, 2004 | 01:58 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
For most typical street builds, the factory setup will be sufficient whether that be 2 or 4 bolt mains. Obviously, you could splay the 2 bolts and use the steel caps for strength, however, in many cases, its a bit overkill (where 4 bolt mains will be sufficient). I would be worried about the rod bolts before the main cap bolts.
How much power are you looking to put out?
theshackle
Mar 5, 2017 06:37 PM
camaro71633
Sep 1, 2015 10:24 AM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
BBSDesigns
Aug 11, 2015 07:39 PM
