7 or 8 Cylinders
Old Oct 20, 2004 | 11:13 AM
jdalla's Avatar
Car: '89 Iroc-Z
Engine: 5.7 TPI
7 or 8 Cylinders
How can you tell if your running on all 8 cylinders or less? i heard that i may be running on just 7 because its an old car...i was just wondering if there is an easy way to find out and if so fix it
Old Oct 20, 2004 | 11:29 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Find the change
Check the exhaust manifolds when you first start it up and see if one area is cold, indicating a cylinder not firing properly.
The other method is to pull a wire off the distributor one at a time to see which one makes no change in the engine. That will show you as well.
Be careful on the second one. I shock the hell out of myself everytime I go to put the wire back on.
It's best to pull the wire while running and notice if there is a change then turn off the motor and reconnect. Then try the next one.
Also besure they are on the right places on the distributor.
I had a bad miss for a week on my winter beater after changing wires. Duh!, two wires (IIRC 3 & 5) were backwards. It didn't backfire or anything, just ran on "kind of" 8 cylinders.
Good luck.
Jp
Old Oct 20, 2004 | 11:33 AM
jdalla's Avatar
Car: '89 Iroc-Z
Engine: 5.7 TPI
thanks I'll give it a try
Old Oct 21, 2004 | 09:00 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
It might actually be easier to just pull the injector connector to test for the dead cylinder. I prefer to stay away from spark plug wires or the distributor on a running engine. ;-)
The injector connectors are rather easy to get to and disconnect, even on a hot engine. And no distributor cover to remove.
Old Oct 21, 2004 | 09:09 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
What are your symptoms?
Old Oct 21, 2004 | 09:48 PM
JP86SS's Avatar
Chicken! LOL!
FormulasOnly
Jul 23, 2018 08:47 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
